  • Guests: 63
Skywarrior (52)
Dark Horse (54)
LD LANGER (38)
12/19 kywalda (63)
12/20 plazmatron (48)
12/20 rm203tech (17)
PlasmaSonic II based SSTC, with poor performance
first  4 5 6 7
LithiumLord
Wed Oct 15 2008, 07:37AM
Dr. GigaVolt wrote ...
You should be getting risetimes of 25-50ns easily and almost perfect pulses.
I doubt that - as mentioned in the first post, the fets are IXFN48N50 which are even heavier than mine (IXFH30N50, as an off-topic - absolutely brutal fets, especially for you can get here for the mere $2!) - and I'm getting around 100ns full swing (from -8 to +12v) - and that is with drivers connected directly to the gates without any GDT.
Cotlone
Wed Oct 15 2008, 09:58AM
Cotlone Registered Member #1383 Joined: Mon Mar 10 2008, 11:09AM
Cheers, I hope it is the cores, it certainly would explain a lot. I'm trying those Jaycar cores now, fingers crossed hey, everyone must be getting sick of seeing this thread!
Wed Oct 15 2008, 11:44AM
Cotlone wrote ...
Actually, I stand correct. Those cores are probably just fine. I dug out my old PSPICE simulations of the Plasmasonic (been a long time), and simulated with your parameters. They actually look like the waveforms you are getting.
Based on this, my advice is to go with what you have. Optimize the windings to get as best waveform as possible. You're not going to get better. Your switching lots of power and at high frequency.
The MOSFETs will get pretty damn hot as you mentioned, but you're running CW remember. Not a DRSSTC. Make sure they're well heatsinked and plenty of airflow (fans)
But also, you want your voltage to high enough so you saturate those MOSFETs. Up to about 12-15V. If you are getting less voltage, then try reducing turns, but also leakage inductance will affect this as well.
Cotlone
Wed Oct 15 2008, 11:29PM
Ah, ok then thanks a lot I'll work on that.
Dan, just out of interest is there any chance that I might be able to have a look at your simulation to help me understand whats going on? I've made a simulation of my equivalent circuit but I haven't modeled the cores. I'm far from a PSpice guru, it nevers hurts to learn though.
Alternatively does anybody know of some MOSFETs which are a little less brutal in the miniBLOC / SOT-227B / ISOTOP package (same as the IXFN48N50)?
Thanks.
LithiumLord
Thu Oct 16 2008, 01:25AM
Actually, things are not as bright. The heat level will drop the maximum current dramatically so even 20amps (there is no ZCS but there IS the magnetizing fully-reactive current, remember?) through the primary will result in a blast. The core replacement is definitely of no use, so you'll have to mess with the drive electronics a bit - try quad separate GDTs with a more powerfull drive (some 14a IXYS drivers will work great there) or just get rid of the GDT completely (like I did - I hate that core/winding/driver overload mess :) ) - those fets should be really great and you'll achieve really huge sparks with them - just it will take time and money, but it's still a good idea!
Thu Oct 16 2008, 11:55AM
LithiumLord wrote ...
14A IXYS drivers aren't need here. They may MOVE heat dissipation to the gate resistor (total heat dissipation DOESN'T change), but performance wise they aren't going to do much for this particular design.
So just how did you drive your circuit without the gate transformers?
I've uploaded my quick PSPICE circuit. Simply rename .ZIP to .SCH. (Its NOT a ZIP file)
]gatedriver01.zip[/file]
Cotlone
Thu Oct 16 2008, 12:57PM
Awesome, thanks very much I'll check that out. I had it running tonight and was getting some decent sparks (best I've had yet), and the music was pretty reasonable. The only thing is that it only tended to work when I held my hands in a particular orientation around the primary (I discovered when tuning), it seems to be independant of tuning. The heat sinks did get nice and warm but cool down pretty quickly with the aid of forced convection.
LithiumLord
Thu Oct 16 2008, 04:20PM
Heh, I'm talking about the fet heat level, not the driver one. You will get a higher drive current and therefore shorter rise/fall times, so switching losses will decrease.
Actually I never tried that out, but I guess that an improved drive, preferably using separate quad gdts (one per gate) with such a high current may make good results even on such a heavy gate.
Those crazy little thingies :) http://i8.photobucket.com/albums/a44/TheBypasser/05052008920.jpg
(8A driver IC-based bipolar optocoupled high-side driver - used four of those for the H-bridge)
first  4 5 6 7
