  • Guests: 68
01/13 si2030 (62)
Can i use it?
LUGIA
Tue Sept 23 2008, 07:34AM Print
LUGIA Registered Member #1706 Joined: Sat Sept 20 2008, 05:41PM
I want to know can it work?
Thank You
1222155265 1706 FT0 2309200856
1222155265 1706 FT0 Scheme2
Linas
Tue Sept 23 2008, 09:20AM
put to primary 220V ac, and have HV, simple cheesey
also,its very danger, because 2KW and 1A in output, keep away from working MOT
Tue Sept 23 2008, 10:00AM
I don't think it will work to use a MOT to do that, you could try but I doubt it will work.
Tue Sept 23 2008, 10:06AM
It will not work. Connect it to mains, but be warned it can draw up to 5000VA from the mains when shorted.
Tue Sept 23 2008, 10:24AM
Why wouldn't it work? I'm sure if you shoved a high enough DC voltage into it, it would start oscillating somehow. suprised
Maybe use one of those bipolar transistor bricks out of an old motor drive. The things they used to use before IGBTs were invented.
Tue Sept 23 2008, 11:20AM
Steve McConner wrote ...
Because there are too few "feedback" turns? If you started to shoving enough voltage into it to start oscillate, the transistor would probably be long dead by overvoltage by that time, not saying the MOT secondary would probably spark over by voltage spikes and higher frequency...
Maybe someone can prove me wrong? smile
LUGIA
Thu Sept 25 2008, 03:54AM
Thank you for help
"few "feedback" turns?" How many turn to add? Oh i forget number of TR it's "2N3055"
OR do you have a other circuitry can be use with Microwave Transformer to make a HV?
Thank You Very Much
Firefox
Thu Sept 25 2008, 04:36AM
Uhhh, yeah. You can plug it into the wall with some balast. Like a 100W light bulb. A MOT is a 50 or 60Hz iron core transformer. However, if you are new to HV, this isn't a good thing to start out with. A MOT is deadly, even when balasted. Find a TV flyback or small high frequency transformer to play with. They hurt like no tomorrow if you are dumb enough to get shocked by one, but generally they aren't deadly. Some other things to get started with are plasma globe drivers and lamp driver boards from scanners.
LUGIA
Thu Sept 25 2008, 03:50PM
Oh Thank you.
Do you have any circuit to use with Flyback(Easy easy and can use with low voltage Please).
teslacoolguy
Thu Sept 25 2008, 04:55PM
the most easy flyback circuit is actually the one you were going to use to power your mot :P. Just wrap the primary coil about 18 turns and the feedback coil about 5 turns around the exposed part of the ferrite core on the flyback. After you build everything just power it with 12v.
