rsg pulsing
Kristian
Sat Sept 20 2008, 01:02PM
Registered Member #611
teslacoolguy wrote ...
I am not trying to make is sync. All i wanted to do is run it at *around* 120bps async. Unfortunately the motor only goes up to 240bps so i would have to get another motor to go any higher.
Hey TCG
Do you have room on your rotor to double the number of flying electrodes? I might be wrong here, as I haven't built an async rotor yet, but if you run with a smaller capacitor value like .06uf or less, it will charge quicker and you will still get a good level of power through the gap at higher brake rates.
