  • Guests: 66
The development of an MMC...
envytea
Mon Aug 25 2008, 08:27PM Print
envytea Registered Member #1653 Joined: Mon Aug 25 2008, 08:02PM
This is my first posting, so, "Hello to all!"
I am building my first Tesla coil. It is a relatively small one: NST is 7500v, 20mA, 150W; 3" secondary. I am deciding on how to go about building the capacitor bank. I am planning on using polyester film caps, but I am unsure of the layout. It seems that several coilers recommend having multiple strings (>4) of caps in parallel for the MMC. This is to better distribute the current. However, since my TC is rather low-power, can I get away with less strings in parallel? I am considering even making the MMC with 2 or 3 parallel strings. I am just trying not to use too many materials and, hopefully, save some money.
Any and all advise would be much appreciated. I will probably post more questions in the near future, mostly regarding this MMC. Thank you in advance.
Later,
envytea
Note to moderator
: I honestly tried to search previous postings for information relevant to my question. However, a key term "MMC" had too short of a string to be a legitimate query. I apologize if this question is redundant in the history of this forum.
Kizmo
Mon Aug 25 2008, 08:59PM
First thing: polyester is crap with high frequences. Go for polypropylene caps.
envytea
Mon Aug 25 2008, 09:50PM
Thanks Kizmo. I am now leaning toward using Cornell Dubilier metalized polypropylene caps.
My target capacitance is 0.007uF for the MMC. If I use 3 strings of 9 0.022uF/2000vdc rated caps, the MMC will have a value of 0.0073uF/18000v. Is this a decent choice? Would it be better to have the total capacitance slightly above or below the targeted value?
Myke
Mon Aug 25 2008, 10:14PM
I would say above because of LTR cap choices are good right?
Coronafix
Mon Aug 25 2008, 10:55PM
Your resonant cap value will be 7nF, so you should go 1.4 times higher than this to have a Larger than resonant cap value.
Hence you should be looking for about 10nF in your cap.
You could go 3 strings of 6 of those caps (.022uF 2000V)
giving you a rating of 12000V @11nF.
Seoul_lasers
Tue Aug 26 2008, 01:54AM
Seoul_lasers Registered Member #1630 Joined: Sat Aug 09 2008, 11:36AM
Coronafix wrote ...
actually I would be going 2.5-3x the input value of AC voltage.
7500Vac - 18.75- 21Kvdc rating.. this is standard practise. The capacitors you need are Polyethylene and on a personal bias CDE942Cs are the best suited for the job because of their self healing capabilities.
Nice thing is your tank cap is pretty small. CDEs will last years if you treat them properly!
Coronafix
Tue Aug 26 2008, 03:39AM
Seoul_lasers wrote ...
I believe this to be overkill, when using LTR the voltages are never going get that high on the capacitor.
I use 24kV for my 15kV NST, and have even used 21kV. I have never had a problem.
The CDE942C series is well tried and tested as the best for TC use. That said, I actually
use the 940C30S47K-F which has a 3kV rating on each cap. The reason I do this is because
those other capacitors aren't available from my supplier in Australia, and it works out cheaper.
Seoul_lasers
Tue Aug 26 2008, 05:42AM
Coronafix wrote ...
I would stay away from 940C caps as they tend to fail at the axial leads
(ends) . If you use the JAVATC calc and go to the section on MMC design you will see what I am reffering to about the voltage rating needing to be at least 2.5x. There is a lot of stress from the capacitors rapidly discharging and this translates into heating of the dielectric. It is best to have some extra voltage rating than not, less stress on them/
Anon01
Tue Sept 02 2008, 10:26PM
Anon01 Registered Member #1589 Joined: Sun Jul 13 2008, 06:40PM
So, what is the resolution on the caps listed? I ordered some from Newark and I received them, but completely forgot about how to construct the MMC, do I use VDC(3 000V), VAC(750V), or the average of the two values(1 875V)? In my scenario it runs to be, using VDC rating, 6 caps per string, giving me 18 000V with a 8 000V transformer. It's not >8 000*2.5 giving me 21 000V, but more than the peak available(V*sqrt(2)), which gives me 11 313.7085V. Am I doing it correctly?
If it feels like I am taking over the tread, say so and I will make a new one. I thought it would be okay since this one is dead, and my question is relevant to these specific cap's specs.
coillah
Wed Sept 03 2008, 12:03AM
coillah Registered Member #1517 Joined: Wed Jun 04 2008, 06:55AM
In an oscillating system you need to use the VAC rating for the caps + the safety factor. It appears as if you have done that, but are a tad bit under the rating for safety (aka cap longevity), IMHO.
There have been several discussions on what the appropriate amount of overrating is for a MMC voltage ratings. I'd say that you're just about right with your rating.
You can build it cheap and worry about the caps failing or you could build it so you never even consider the caps :)
