  • Guests: 68
250,00v table top tesla coil. Help!
first  2 3 4 5
Seoul_lasers
Sat Sept 13 2008, 12:48AM
Seoul_lasers Registered Member #1630 Joined: Sat Aug 09 2008, 11:36AM
Sorry, I had problems uploading when i went to post... Error file deleted. It was a .jpg...
try this again.
1221266916 1630 FT52821 Circuit
Kristian
Sat Sept 13 2008, 02:31AM
Kristian Registered Member #611 Joined: Wed Mar 28 2007, 11:40PM
I'd rewire it just like Seoul Lasers diagram. Ditch the choke. Set the spark gap with the transformer output before hooking it up to the tank circuit. You are probably over-volting the transformer from an improperly set gap.
I don't think this coil you have was designed very well.
Seoul_lasers
Sat Sept 13 2008, 03:55AM
Actually the choke could also be causing problems for you. There is some inductance to the choke and it can actually raise your tank voltage. It can also cause problems with the transformer. Kristian is totally right... choke is going to lead to problems. The design was NOT properly thought out. this is a common problem with Information unlimited.
*********Capacitors are charge via one leg only, NEVER EVER directly across the hot and ground of ANY transformer.
M_Ling
Sat Sept 13 2008, 03:54PM
M_Ling Registered Member #1652 Joined: Mon Aug 25 2008, 04:47PM
so should I still ground the building ground to the XFMR body?
Seoul_lasers
Sun Sept 14 2008, 06:16AM
M_Ling wrote ...
NO, you use a separate ground for RF. RF grounds to the water pipes or what ever. Never use house ground for this.
Transformer is connected to house ground.
It sounds like you should rebuild the circuit. This is why you keep blowing your transformers.
M_Ling
Sun Sept 14 2008, 10:45PM
I just bought a potted 9KV/.03 XFMR and will rebuild the circuit without the choke, per your diagram. Keeping the XFMR common/ground away from the House ground. Hopefully this will fix everything. Im just hoping that my CAP can take the new XFMR's output.
Seoul_lasers
Mon Sept 15 2008, 09:22AM
XMFR goes to house ground. TC secondary and discharge wand goes to RF ground which is separate and goes to a copper water pipe... or spike in the ground.
M_Ling
Sun Sept 21 2008, 04:34AM
Ok, so Im slightly confused now, I got my new XFMR and wired it per your drawing. The XFMR has two output leads and no way of telling anything like Hot and neutral. With the CAP on the back end of the spark gap and the XFMR wired straight to the gap all I am getting is a small spark directly from the XFMR. No more than if I held the XMFR leads to each other. Certainly not the crack that I was getting from the old design. I feel like I am missing a ground wire somewhere, the original plans had the groung from the wall outlet directly meeting up with the XFMR lead at the spark gap. But it seems to me everyone is saying not to do that.
M_Ling
Mon Sept 22 2008, 03:04PM
Im at a loss. I cant get anything across the spark gap but the XFMR current when everything else is unplugged as soon as I plug in the CAP circuit I get nothing. I tried the new wiring scheme and the old and still nothing. Its possible the CAP is now bad but since it never ran with it Im not sure if its that. The CAP looks fine but its hard to tell. The new power supply may have been too much for it.
Another strange thing about the "Info Unlimited" plan is that the primary and secondary are wired together at the base of the secondary were from what I can tell the secondary should only have a ground wire and nothing else going to it.
Is there anyone in the Philadelphia area that would like to be commisioned to get this TC up and running? At this point in time it is more important to get it running than it is to say I did it myself.
Bamacoiler
Mon Sept 22 2008, 03:18PM
Bamacoiler Registered Member #1628 Joined: Wed Aug 06 2008, 08:48PM
I have used this exact capacitor and it died in short order. It didn't last 1 day so you are probably right about the capacitor being bad. When my capacitor died you couldn't tell by looking at it so you might want to test to confirm.
first  2 3 4 5
