  • Guests: 54
J. Aaron Holmes (50)
Lukasz Sterczewski (36)
Coileone (40)
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
Help! My coil almost works
Coronafix
Fri Aug 08 2008, 03:19AM
Arclight has a very good point, with a shitty gap you will get shitty performance.
And make sure the strike rail wire is nowhere near the primary. And of course like Ultra said,
make sure it's not a shorted turn.
Zorink
Fri Aug 08 2008, 03:41AM
Zorink Registered Member #1292 Joined: Wed Feb 06 2008, 04:09AM
Thanks for the advice everyone. My strike rail is 1 inch short of a full circle - should I cut more out? I'll try changing the spark gap and let you know how it turns out. What kind of gap would you recommend?
Ultra7
Fri Aug 08 2008, 04:02AM
Coronafix wrote ...
My first spark gap was an RQ or "Richard Quick" style spark gap.
or
Very easy to build, and with more electrodes.
With a large number of electrodes and a larger discharge surface, it will go longer between cleanings, and give you differing gap widths to choose from.
I made mine with six electrodes and ended up adding a seventh to see if the increased gap width would improve the performance.
One lead is mounted permanently on the far end electrode, and one has a nice thick alligator clip so that I can clip on to whichever other electrode I want for the effect I want.
Worth a try.
There is also the sucker gap that many have come to love as well.
Ultra7
Fri Aug 08 2008, 04:04AM
Zorink wrote ...
Id remove another 2 to 3 inches, and then check your performance with that.
As for the gaps, see above.
Herr Zapp
Fri Aug 08 2008, 05:11AM
Ultra 7 -
As long as the strike rail is not a closed loop, the distance across the gap doesn't matter: 1/10 of an inch, or 10 inches. It's only when its an electrically closed loop that any current can be induced in it from the primary coil's magnetic field.
Zorink -
Very nice looking coil! However, the coil should be capable better performance than you're currently getting.
A few suggestions:
1. Is the black surface that the spark gap is attached to wood? If so, I'd mount the spark gap electrode holders on a piece of insulating material (phenolic, G10, or any other piece of plastic you might have, or use some of the ceramic insulators like you used on your Terry filter to isolate all HV from any wood structure.
2. Double-check the value of all the bleeder resistors used in the Terry filter, and in your MMC; make sure that they are all 10 meg (or higher).
3. You stated that you "tuned" the coil using an oscilloscope & signal generator. Can you describe exactly how you did this? When measuring the resonant frequency of the primary circuit, did you include the length of all the wiring connecting spark gap, MMC, and primary coil?
Regards,
Herr Zapp
Zorink
Fri Aug 08 2008, 05:34AM
Herr Zapp wrote ...
A few suggestions:
1.Yes, the black is wood. I'm going to try the RQ gap that Ultra7 posted so that should get it away from the wood as well.
2.All resistors are 10 meg.
3.This is how I tuned it. Link2
Dr. SSTC
Fri Aug 08 2008, 08:04AM
Dr. SSTC Registered Member #1407 Joined: Fri Mar 21 2008, 07:09AM
i can see you took your time building this coil
cant wait to see it working properly
Coronafix
Fri Aug 08 2008, 09:55AM
My first spark gap was a multiple static gap like the Richard one but not inside a tube, worked very well.
Next I tried the sucker gap and had increased performance, but the noisy vacuum cleaner is a trade off.
Performance was about 10% spark length increase.
Just try messing with the tuning, you'll quickly see the difference.
Herr Zapp
Fri Aug 08 2008, 10:24PM
Zorink -
Again, when you measured the resonant frequency of the tank circuit, did you include the length of all the wiring between the primary coil, MMC, and spark gap?
A better description of the measurement technique can be found at: Link2
Just short the spark gap, and connect the signal generator across the tank cap. This method automatically includes all the inductance of the actual wiring in the measurement.
Also, you will probably find that "better" initial spark output will be obtained if the resonant frequency of the primary is initially adjusted to 10-12% LESS than the measured resonant frequency of the secondary. This is supposedly because as HV charge accumulates on the toroid, it creates a cloud of ionized air all around the toroid, which increases its effective size, which increases its efffective capacitance, which lowers the actual resonant frequency of the secondary. Basically you are tuning the secondary to the operating frequency of the secondary, not the "static" resonant frequency.
Regards,
Herr Zapp
Hhhhhhhhh
Fri Aug 08 2008, 11:53PM
Hhhhhhhhh Registered Member #1340 Joined: Thu Feb 21 2008, 12:47AM
sorry
