  • Guests: 63
Coil Wrapping Style
Ryan
Fri Aug 01 2008, 05:33PM Print
Ryan Registered Member #1606 Joined: Fri Jul 25 2008, 02:40PM
As opposed to wrapping a coil from bottom to top, I have recently seen someone wrap their coil in a different fashion. The coil started by folding the length of wire used in half, then, the wrap started from the middle of the coil as opposed from the bottom, up. the wire (that was folded in half) then was wrapped towards the bottom of the coil, from the middle, while the other half of the folded wire was wrapped towards the top. Essentially I guess this left a tiny loop in the coil where the wire had switched directions. Why is this? What benefit would it provide?
Thanks, Ryan.
Tom540
Fri Aug 01 2008, 06:13PM
Tom540 Banned on 3/17/2009.
would be faster as long as you had control over it but to me that sounds like a huge pain in the ass.
coillah
Fri Aug 01 2008, 07:14PM
coillah Registered Member #1517 Joined: Wed Jun 04 2008, 06:55AM
how would it be any faster?
Fri Aug 01 2008, 07:41PM
Sounds more like its for making a coil with 2 polarities
coillah
Fri Aug 01 2008, 07:49PM
MadsKaizer wrote ...
/agreed
however... what would that do? wouldn't the fields cancel?
Tom540
Fri Aug 01 2008, 07:50PM
coillah wrote ...
If you start in the middle and are winding half one way and half the other way then you would be doing twice as much winding with at once. Once the wires got more spread out it would be hard to keep track of. The two halves would be of opposite direction too.
Shaun
Fri Aug 01 2008, 09:04PM
If you used this method for or TC secondary, or anything high voltage, there would be a lot of corona/breakout where that little loop is.
Other than that I agree with Tom, about the pain in the ass part.
Ryan
Sat Aug 02 2008, 02:47PM
Hmm.. I saw a picture on the net (which is why i started this thread), it was a schematic that somebody had drawn up on the computer, and the reason I ask is because the person drew a loop in the secondary and made a note beside it saying "<<---- -Add loop".. if anyone comes across a picture like that, post it!
Thanks
Coronafix
Sun Aug 03 2008, 12:19AM
This would be a way to make a bipolar coil, but it would be bucking at the middle. The loop could be used to tie the centre to ground.
Ryan
Sun Aug 03 2008, 04:16PM
Great, thanks for your help guys.
