  • Guests: 49
01/13 si2030 (62)
Interesting "lifter" observation
Antonio
Sat Jul 26 2008, 02:59AM
I used plastic foil cut from a transparent plastic folder. 5 mm strips folded in "L", glued with cyanoacrylate glue. Foil from transparencies may work too, but the ones that I have here are or too thin or antistatic (partially conductive). Metalized plastic foil probably works for the skirt. I would like to make a very light one, operable from an electrostatic machine. I can obtain more voltage easily, but at most 100 uA of current, with the machines that I have.
