  • Guests: 56
I found some IGBT's are they any good for a large drsstc?
Rollingblackout
Fri Jul 18 2008, 01:48AM Print
Rollingblackout Registered Member #1524 Joined: Sun Jun 08 2008, 05:25PM
I was digging through some stuff at work and found a 150 amp dc power supply and inverter parts. I'm not sure what would make these igbt's good or bad for a drsstc so ill ask for a little input here.
Link
Dylan
Fri Jul 18 2008, 03:02PM
Dylan Registered Member #1024 Joined: Sun Sept 23 2007, 10:56AM
Nice find!!
Not sure on the spec, sorry , just admiring the shiny new fullbridge and heatsink :).
Im currently a halfbridge 'Brick' coil, and not having any trouble below about 250Khz.
If I had that bridge lying around I'd be winding up a nice big sub 100Khz secondary and going for it !!
Rollingblackout
Fri Jul 18 2008, 03:32PM
Here is a data sheet on the igbt's
]cm150du-12h.pdf[/file]
Fri Jul 18 2008, 04:13PM
Is there any use for a single IGBT brick? A colleague gave me a old 1000V/200A brick
Dylan
Sat Jul 19 2008, 12:34AM
MadsKaizer wrote ...
If its a dual device then sure , run it as a half bridge, My halfbridge TC runs on a single toshiba MG100Q2YS1 200A brick and tis bullet proof (so far) :)
Sat Jul 19 2008, 05:20AM
Dylan wrote ...
It is not a dual device, just a single with 2 emitter terminals, its a Toshiba MG200N1US1
Dr. SSTC
Sat Jul 19 2008, 07:06AM
Dr. SSTC Registered Member #1407 Joined: Fri Mar 21 2008, 07:09AM
lol make a REALLY big 555 flyback drive and run it from rectified mains
Sat Jul 19 2008, 09:24AM
you can make an OLTC wink
Dylan
Thu Jul 24 2008, 08:25AM
Or a low frequency Class-E sstc :
http://www.richieburnett.co.uk/hfsstc.html
coillah
Fri Jul 25 2008, 03:25AM
coillah Registered Member #1517 Joined: Wed Jun 04 2008, 06:55AM
Where do you work blackout?
