  • Guests: 47
RoV IW3IPD (63)
01/13 si2030 (62)
Universal driver
Mon Mar 20 2006, 01:34PM
Possible, when the IGBT is OFF, the primary and the cap forms a LC res circuit there.
I tryed today with a 1 uF cap in parallel with the primary of the ignition coil (run as parallel LC circuit). Make some longer and hoter arcs. You just have to find the right cap value and excite the primary at the right frequency...
Mon Mar 20 2006, 01:49PM
I used to cook 2N3055s with primary cap on IC and sparks weren't a lot bigger.
It resonates and coil builds up too much voltage on primary at certain frequency so it overvolts the transistor.
That probably won't happen to IGBT but be careful.
Simon
Tue Mar 21 2006, 12:02AM
Firkragg wrote ...
My universal driver is far simpler. It's an MJ10012 driven directly from a tunable 555.
Im wondering how don't you fry NE555, bipolar transistors need lots more current than it can give.
At least small darlington would help.
The MJ10012 is a darlington. Have a look at the datasheet and you'll see it's perfectly capable of running almost anything you throw at it from a 555.
Tue Mar 21 2006, 02:30PM
Sorry then, i was too lazy to look at datasheet cry
I used darlingtons sometimes but they too overheated NE555, so I needed one more transistor and still didnt saturate the main driver.
I realized its wrong approach and using BDT worked far better...
Also driver transistor itself likes base to be pulled down to 0 by some way, I got better preformance when I used push-pull as pre-driver.
im wondering what results you had, what voltage/spark did you usually get?
Tue Mar 21 2006, 02:58PM
It is nothing special about the sparks and arcs. Only 5-6 cm between needle electrodes, i suppose that it is under 50 kV.
But I had to try this driver also. Sometime ago, I built a lot of driver types, but no one with an astable and push pull transistors.
http://www.geocities.com/teslina/drivers.html
