  • Guests: 44
Alu flashing as tesla coil primary?
Sun Jun 22 2008, 03:09AM Print
I recently hatched the idea of using flashing for a primary. It sounds like it will be cheaper than copper pipe. But would it work as good as copper?
Shaun
Sun Jun 22 2008, 03:36AM
Yes, aluminum metal works just as well if not better than copper in a TC primary. IIRC, its slightly less conductive but has better skin depth. Factor in reduced cost, reduced weight, and reduced oxidation, and i think we have a winner!
cjk2
Sun Jun 22 2008, 04:21AM
The only problem I can see is making connections to the primary when you can not solder to it. Clamp or bolt your wires to it and it should work just fine.
Mon Jun 23 2008, 12:42AM
Thank You!
Mon Jun 23 2008, 01:56AM
Yep. Al flashing is commonly used in Tesla coils.
Andyman
Mon Jun 23 2008, 06:17AM
But I think flashing is most commonly used in the home made capacitors. Flashing doesn't usually come in sheets any less than 6" wide, so you would need to cut it .
teslacoolguy
Mon Jun 23 2008, 06:24AM
You can just take the whole rool of flashing and cut it with a hacksaw or something prior to unwrapping it and then you wouldent have to worry about cutting it as you go along.
Mon Jun 23 2008, 06:21PM
teslacoolguy wrote ...
Ha thanks! That just saved me some hours(cause i do my work slow so i dont mess it up :P
Mon Jun 23 2008, 07:50PM
I did that with my band saw; it worked OK but some of the aluminum stuck together so i had to pry it apart in the end to unroll it. Id suggest figuring out some other method of cutting the aluminum if you want a nice edge on it.
In the end i scrapped my primary made from 3" wide aluminum strip because it was too hard to keep it from arcing to the secondary with the extremely sharp edges of the primary. Having round copper tubing instead really does make a good difference.
Andyman
Tue Jun 24 2008, 01:08AM
Oh yeah, didn't think about that. With flashing, you have really sharp edges. Some people have used spring bronze weatherstripping as a primary:
Unlike the aluminum flashing with the sharp edges the brass has folded edges.
