  • Guests: 42
SGTC powered by ignition coil - sparks over 30cm!
Coronafix
Sun Jun 29 2008, 11:05PM
Wow Mates! Good work. Your rolled caps look like a spark gap in that pic, and there are racing arcs on your primary!?!
Looks good though.
teslacoolguy
Mon Jun 30 2008, 12:52AM
Yea i would be a little concerned about the corona in those caps. Although they make a cool glowing effect smile
Mates
Mon Jun 30 2008, 06:06AM
Coronafix wrote ...
I also noticed those spark-overs into the primary... I'll have to make the primary more flat-like
Regarding the caps: Yes, those are the most lossy part of the setup - no doubt... However, accordig to their finall rating (13nF/50KV) they save a lot of money wink . Also, despite it looks that they must suffer a lot, in fact they become only litle bit warm. The internal damage on the dielectricum is visible (craks like pattern) but not becoming worse. It looks that the fact the caps are sealed on the ends led to elimination of all the available oxygen inside, by ozone-plastic reactions and now they can stand anything. Hopefully one day I'll get a vacuum pump and make those caps oil based...
Dr. H.
Mon Jun 30 2008, 06:07AM
Hey - I like the caps more than the sparks itself - hee hee. Good work Mates, keep it up smile
Cheers Dr. H.
Mon Jun 30 2008, 01:41PM
Nice results Mates! This gave me some ideas for some new experiments..
Mates
Fri Jul 04 2008, 10:47PM
Few changes on my coil…
First of all I cut the secondary a bit so now it is all dipped inside PP tube filled by cooking oil. All sealed by hot glue. The coil is smaller and looks a bit better like this… I also increased the power of the Iggy driver. I don’t think I can go much further with single transistor. I’m still thinking about bridge rectifier for the Iggy output, but it is a lot of diodes – do you somebody knows whether this makes any sense?
Movie of this new set up is here Link2
This time only few pictures with my shitty camera (my Samsung GX10 will be back in my hands soon, so I have big plans for a new of set art-like photographs based on this small coil…)
Cheers Mates
1215211625 1025 FT47425 Pict3299
1215211625 1025 FT47425 Pict3305
Avi 000019099
Avi 000013633
Mates
Tue Aug 05 2008, 08:10PM
I changed the primary today and a small miracle happened... amazed The longest sparks are over 20cm!
The coil is becoming very loud now, my neighbors know when is on frown That's the biggest disadvantage of the SG based coils. More power is in home indoor conditions problem. But I love the sparks of SGTC and the fact you can use top load without break out.
1217966828 1025 FT47425 Sgtc New Primary
Alexandre
Tue Aug 05 2008, 09:40PM
Alexandre Registered Member #1228 Joined: Tue Jan 15 2008, 01:08AM
Hey Mates..
what the dimentions of your coil now??
Mates
Fri Aug 08 2008, 08:16PM
Hi guys, today I tried to use bridge rectifier for my IGGY output and it increased the power significantly. Now the sparks lenght reaches 30cm which as I believe is a real record for an Iggy driven coil...
1218226540 1025 FT47425 Sgtc Bridge
1218226540 1025 FT47425 Bridge
Tesla011 wrote ...
Hey Mates..
The secondary: 45cm hight /4.5cm diameter, in cooking oil, approx. 1000turns
Primary: 4 turns, 13cm diameter (multiwire data cable)
Caps: rolled 7.2 nF
Power source: Iggy coil removed from casing and dipped in cooking oil
Power consuption:
Firefox
Fri Aug 08 2008, 08:36PM
Awesome! I just got an ignition coil, so I'll have to try something like this soon. What is the big metal can next to the TC?
