  • Guests: 63
SGTC powered by ignition coil - sparks over 30cm!
Mates
Sat Jun 14 2008, 10:46PM Print
Hi guys,
I build this simple ignition coil driver Link2 and tested it as power source for my small SGTC. The result is not bad and I plan to increase the power soon, so maybe it can be even better…
The HV diode and HV caps are both home made. (The caps are immortal!). Here are the links for the protocols Link2 Link2
Unfortunately I have only very bad compact camera at the moment so the pictures are very poor quality.
Video of the coil in action: Link2
Hazmatt_(The Underdog)
Sun Jun 15 2008, 08:03AM
Very Cool! Since you're using a DC topology you could also investigate some different primary and secondary coil geommetries and see how it affects your performance.
You might want to try fewer primary turns so your di/dt is higer in the primary and see how that improves spark length. You might also want to play with a flat primary and coupling to see if you can get a maximum spark length, just for fun.
Mates
Sun Jun 15 2008, 12:43PM
I played with the primary today... I think not bad for a single iggy wink
video: Link2
Ken M.
Sun Jun 15 2008, 12:55PM
Very nice, Although did you notice you're losing power with secondary corona and discharge, I'd say aboy 1-40 turns from the top?
flannelhead
Sun Jun 15 2008, 01:22PM
Wow! amazed
I bet the iggy is getting kinda hot...
Mates
Mon Jun 16 2008, 06:20PM
Iggy gets hot, but after long minutes of operation... so not such a big problem. I have to rather solve a better spark gap and also the primary is still not perfect.
Few more pictures with better camera, I like the beauty of SGTC more and more...
1213640352 1025 FT47425 Bulb1
1213640353 1025 FT47425 Hairy Coil
Tue Jun 17 2008, 04:23AM
I have a Tesla coil powered like that. How many inch sparks? Mine has 3 inch.
Mates
Tue Jun 17 2008, 07:54AM
Weston wrote ...
Check the video - the longest sparks are close to 20cm (almost 8 inch). The topload diameter is 13 cm)...
Mates
Sat Jun 21 2008, 10:54PM
Today I finnished new primary and icreased a bit the power of the iggy driver...
BTW: I have question, do you somebody knows whether using a bridge rectifier would provide resonably more power from the iggy output?
Avi 000013699
Avi 000005766
Avi 000006033
1 Copy
Mates
Sun Jun 29 2008, 10:06PM
Finally, I borrowed a bit better camera so I could make a bit better pictures...Now, it rises a question how much more power I can get from single iggy??? I'll try to add 30% more power tomorrow... Maybe something will die, if not I'll send new pics and video wink
1214776773 1025 FT47425 Iggytc2
1214776773 1025 FT47425 Iggytc1
BTW: Hmm, not so much responses to this thread… Maybe it is only really boring little project, I know. In general this coil is only about exploring the limits of Iggy coil as a power source for SGTC and also what can stand my home made caps. Both surprised me...
