  • Guests: 42
J. Aaron Holmes (50)
Lukasz Sterczewski (36)
Coileone (40)
What is he using?
KresoLiubov
Thu Jun 05 2008, 04:58PM Print
KresoLiubov Registered Member #1153 Joined: Mon Dec 03 2007, 07:27PM
I was speaking with a friend in Germany i didnot speak for some time.
He has bought a SSTC from this guy Link2
Later he trade it off for some other thingies.
He says me they tortured this coil for all nights half of year without turn off and coil worked, worked, worked...
Does anybody have idea which circuit is he using or what topology? I'm reading his claim "that circuit that he use nobody discovered until now and there is no IC-s, except in the "interrupter" which he calls BPS control.
cjk2
Thu Jun 05 2008, 08:01PM
I see 2 ic sockets on his board, and possible some voltage regulators. Looks like a DRSSTC with a full bridge drive to me. I doubt there is anything special about that design, just a standard DRSSTC circuit maybe with secondary or primary current feedback.
Tom540
Thu Jun 05 2008, 08:35PM
Tom540 Banned on 3/17/2009.
Its not even a drsstc as far as I can tell. It only runs at 5bps max but still requires an ac fan. There are also some little ics or something next to each igbt.
KresoLiubov
Fri Jun 06 2008, 04:36AM
Im sure 100 % its not a DRSSTC. And im still amazed at those little heatsinks. Black box on right side is fan ?
Here is layout
1212727015 1153 FT46678 Layout
Edit: I was digging on his site and found this more images, clearer and worse. Also i found some scope waveforms but nothing useful
Th
Th
GeordieBoy
Fri Jun 06 2008, 09:41AM
Clearances from the DC bus wiring to ground look worryingly small! Not good dead
1212745096 1232 FT46678 Clearance
KresoLiubov
Fri Jun 06 2008, 12:36PM
GeordieBoy wrote ...
If i understood good these 2 screws hold AC transformer for logic supply
Mates
Fri Jun 06 2008, 01:36PM
the whole design looks very crapy so I'm also surprised what he can do with it. One of the bugs must be gate drive and the small (8pins) is most likely 555 timer. The main question is the one remaining bug. It could be PLL since it has antena feedback, you can see antena in one of the pictures on his web page (the older models).
BTW: here is a video of that coil in action Link2
Ken M.
Fri Jun 06 2008, 08:42PM
The smallest chip I could see looks more like a 6pin chip more then an 8pin chip.
1212784928 618 FT46678 1212745096 1232 Ft46678 Clearance
teslacoolguy
Fri Jun 06 2008, 09:07PM
Yes indeed it is a 6 pin chip.
Sun Jun 08 2008, 04:40PM
Has no one noticed the black wire going through the GDT? I believe he is using the primary current to drive the IGBT gates through a CT. The 2 film caps on the left are the resonant cap.
The 6-pin chip is likely an opto-coupler for a TRIAC (or perhaps some other device) to gate his power source on and off.
