  • Guests: 23
  • Most ever online: 441
GhostlyFigures (36)
10/05 GhostlyFigures (36)
10/06 Ivan Kalafatic (17)
10/07 Pyromaniac (34)
WTB: Pole Pig
sparky99
Wed Jun 04 2008, 08:44PM Print
sparky99 Registered Member #1159 Joined: Fri Dec 07 2007, 02:10AM
Hi All,
looking for a pole pig, 5KVA with dual bushings up top, 120 / 240 secondary, 13,200 primary. No PCB's , please. Sources? Want a 5KVA unit cause it's small compared to some of the P.P. you guys have & I have less than no room cry
Sparky99
Bob
Billybobjoe
Wed Jun 04 2008, 08:50PM
Billybobjoe Registered Member #396 Joined: Wed Apr 19 2006, 12:55AM
I would personally recommend searching locally. You can certainly get one over the internet but a deal including shipping will likely be hard to come by - especially with such specific requirements. Unless someone on here has a cheap local source and would be willing to ship one . . .
J. Aaron Holmes
Thu Jun 05 2008, 08:59PM
5kVA units are actually pretty hard to find! 10kVA is ultra common. And in fact, if you check out docs from Cooper and other pole transformer manufacturers, you'll see that they often use the exact same size can for 5kVA and 10kVA. The only thing you'd save on is weight. Case in point: Link2
Definitely try and talk to the salvage folks at your local utilities if you haven't already. It's worked for me. Another option would be to mail D.C. Cox (a.k.a. "Dr. Resonance" on the TCML). He always has a stockpile of 14.4kV 10kVA units priced to sell, and ships from Wisconsin (somewhere). Or if you go to Cheesehead (I've always wanted to but never have), then you can pick one up from him there. Here's a pic of D.C.'s pig pen at Cheesehead: Link2 People cart them off for < $150, I think!
EDIT: Hmmm... The Cooper doc above also says that the *weight* of the 5- and 10kVA units is the same mistrust Although maybe that's actually correct; maybe they wind the 5kVA units with #40 wire and avoid a meltdown by putting 2x the oil in wink Nahh... I'm voting for typo!
Cheers,
Aaron, N7OE
Hon1nbo
Sat Jun 14 2008, 04:17PM
I think amazing1.com has them from time to time.
J. Aaron Holmes
Sat Jun 14 2008, 11:00PM
DaJJHman wrote ...
Indeed, but they want $900 for one. suprised I sure hope they're brand new! Otherwise, that price just doesn't make any sense.
Cheers,
Aaron, N7OE
rp181
Sun Jun 15 2008, 12:45AM
amazing one sells everything overpriced.
Ultra7
Sun Jun 15 2008, 06:01AM
rp181 wrote ...
Find me a 3"X12" Spun aluminum toroid anywhere in the world.
Then find it cheaper than Amazing1 has it for.
Yeah, it's not a John Freau, but it works.
Not all their stuff is overpriced.
