  • Guests: 60
12/06 Dago (37)
12/06 Z28Fistergod (39)
12/06 JonIverson (45)
HV Desk Toy
Thu May 29 2008, 09:55PM
Yes but how does they flyback circuit work? there is 5 windings Verse the 6 that other designs use.
Fri May 30 2008, 12:38AM
by the flyback circuit I assume you mean the camera charger? I honestly don't know what magic occurs in that circuit, I just took the parts off of the camera pcb and soldered remade the circuit without the pcb. The board I started with only had the 1 resistor and 1 transistor on it (aside from the rectifier diode and trigger circuit).
Firefox
Fri May 30 2008, 03:27AM
It is hard to tell from the pictures, but are the caps discharged directly into the winding as a short? Or is there more to it than that? I just got a hold of 5 CRT monitors and I have three of the boards out already, and I as I was thinking of things to do with them, I stumbled onto this. I was thinking perhaps of using my mini CW multiplier to charge up one of my homemade 22uF 20kV caps and dumping it into something like this, but somehow that doesn't seem like a good idea.
Fri May 30 2008, 03:39AM
Firefox wrote ...
Your kidding me right? Not about the idea, but the thing about a homemade 22uf capacitor? How did you do that?!
Anyway, i don't think a flyback could handle that. If you already have 20kv why do you need anymore? The only way to get a whole lot more is a tesla coil. Ha i am prolly wrong about that. You can use a marx generator. My favorite is uzzors's. It was made with all simple stuff, but produces quite a spark!
Firefox
Fri May 30 2008, 03:59AM
Oops, I meant 22nF heh. Or I just used 1000 of my 22nF caps to make a 22uF cap. But in all seriousness, do you think a flyback could handle a 20kV input pulse for that split second?
Fri May 30 2008, 04:35AM
Firefox wrote ...
Well i did make a flyback driver with a tesla coil circuit. It was about 2kv transformer from a bug zapper and it was a .5nf capacitor. I would say that the flyback failed shortly after because i drove it too hard with that circuit, but it was a very small flyback putting out quite long but thin sparks.
I would say if you kept the gap small on the flyback output and the trigger gap on the cap(figuring you would use a spark gap as a trigger)it could probably go through a few pulses( more like 100's).
rp181
Fri May 30 2008, 01:14PM
heh, i tried that with a SGTC, arcs were crappy.
Sun Jun 22 2008, 02:12AM
does anyone know if it would work with two inverse flash bulb trigger coils? They output over 5kv.
Sun Jun 22 2008, 02:16AM
You could use the trigger coil, although they have a limited amount of power that they can output. It is certinly worth a try!
teslacoolguy
Sun Jun 22 2008, 03:17AM
i have overdriven a trigger coil up to 10kv without any problems but the spark was very dim and i couldent feel anything when i used my finger as an electrode.
