  • Guests: 31
sbs_2010 (34)
SoundDoc (50)
10/09 sbs_2010 (34)
10/09 SoundDoc (50)
10/10 Ryan Parle (44)
Big mo-fo ferrite HV transformer driving (another CCPS/SLR inverter)
Tue May 20 2008, 06:32AM
All this makes me want to make my own, is Ebay the only good place to buy big ferrites?
Tue May 20 2008, 05:50PM
Pretty much. That or Hamfests, which we don't have in Norway.
Tue May 20 2008, 06:39PM
Ace7one wrote ...
Sat Nov 08 2008, 12:48PM
I'm going to continue on this project, as I've found a solution to the corona problem, namely oil submersion. It's messy, but the best solution I can think of. So far I've relied on math to estimate the amount of primary turns I need, but is there a way to find this in practice? I placed a 4 turn secondary winding on the transformer and started with 20 turns for the primary. (Here's the datasheet for the core.) While decreasing the amount of primary turns I watched the secondary waveform, but eventually I was at 7 turns or 45V/turn at 50kHz with only minor signs of drooping on the squarewave. Is this the right way to check for saturation, and how does loading a winding affect saturation?
EDIT: Does anyone know the highest flux density and frequency I should operate this core at? (N27)
Sat Nov 08 2008, 09:39PM
Uzzors wrote ...
I would guess around 0.15 - 0.17 Tesla.
Magnetics has a lot of good literature
and you should read this one:
This one is a must:
I know it would be better with info from Epcos, but they are really arrogant. I once asked if they had cores that would cover the needs for Daniel and my CCPS, and they just told me to contact a transformer manufacturer, because the design of a 50kHz high voltage transformer needs special skills.
Ferrites can be run to saturation below 20kHz without getting too hot. at higher frequencies, the core is said to be loss limited. This means that the core losses have to be diminished by lowering the flux density.
Cheers, Finn Hammer
rp181
Sun Nov 09 2008, 03:55AM
Epcos isnt arrogant, i almost got a 20kJ capacitor bank sponsorship =p
Ide say the best method is to build a variable drive, and play with frequency.
Sun Nov 09 2008, 09:00AM
rp181 wrote ...
I guess I put it bluntly. Of course Epcos are many persons, and the responce you get, depends on the person you happen to get in contact with. However, I have noticed a different, more friendly, attitude from american companies, when approaching them for information. Americans more often respond with: Why don`t we just send you a sample, then you can find out if it works. European style more like: If you don`t know already then go study more before wasting my time. That`s what I ment with "arrogant".
When you say "almost", what does that imply: Did you get the caps or only almost, but not?
rp181 wrote ...
There has been ferrites around for a long time, and the television flyback transformer moved the application of them out of the black arts and into the well understood enginering tasks. It is possible to arrive at better than ballpark values with less than starting from scratch. No need to invent the wheel over again.
Cheers, Finn Hammer
rp181
Sun Nov 09 2008, 02:18PM
I say almost because, they offered, but my school's district legal department said it would open them up to all kinds of liability issues =(.
What you say makes sense...
Dylan
Sun Nov 09 2008, 10:47PM
Dylan Registered Member #1024 Joined: Sun Sept 23 2007, 10:56AM
101111 wrote ...
Inverter microwaves have an excellent ferrite core in them, ready wound with a nice lenth of litz wire for your primary.
Sun Nov 16 2008, 04:54PM
I picked a number of primary turns the easy way. This transformer has to produce between 16 and 18kV, and I have two secondaries with approx 225 turns each. So I need 8 turns.
I was about to pour oil today, when I decided a few quick continuity and inductance checks were in order. Everything checked out except the primary inductance. For the first it's 370µH according to my LC meter, when it was 5.5mH during the last build. The difference in turns is 8 now compared to 10 earlier. This is with no secondaries.
With secondaries installed things get worse. The primary inductance drops to some 5-10µH. Now I'm 90% percent sure these secondaries have no shorted turns. Also, when measuring their (secondaries) inductance while on the core it's in the order of 20mH each. If they had a shorted turn their inductance could surely not be so large?
Did I damage my core somehow while pushing the V/turns? At one point I was up to 0.5T IIRC. Or do I have to keep looking for a shorted turn somewhere?
