  • Guests: 65
01/13 si2030 (62)
I obtained a pole pig
teslacoolguy
Fri May 09 2008, 06:18PM
some nice looking switchgear you have in the backround cheesey
Also i ballasted it today with a 1000W mot and here is the result Link2
lpfthings
Fri May 09 2008, 11:35PM
lpfthings Registered Member #1361 Joined: Thu Feb 28 2008, 10:57AM
Looking good! I think you could get much bigger arcs, my NST almost acheives that.
Firefox
Sat May 10 2008, 02:55AM
Just to point out, there seems to be an arc on the non-chicken stick terminal, about 3 in down from the top. Don't know if that is bad or not.
teslacoolguy
Sat May 10 2008, 03:04AM
Ooo yea that is just a reflection of the arc because the ceramic insulators are very shiny. smile
Andyman
Sat May 10 2008, 08:38AM
Quicksilver, I believe this is the coil you heard about:
It was at the 2008 AZ teslathon. It was powered by a relatively low power pig. SUPER loud.
quicksilver
Sat May 10 2008, 03:06PM
YES! That was it! I was astounded. From what I could see and read, it's power, workmanship, & overall execution were beyond belief.
Most of the examples were fantastic, but that was creative & showed a deep professionalism.
Experimentonomen
Sat May 10 2008, 03:39PM
How in the name of god would your parents let you buy that ? suprised
teslacoolguy
Sat May 10 2008, 05:24PM
Well lets just say they trust me wink and also i have been working with high voltage for over 2 year and i know what i am doing.
Kolas
Sat May 10 2008, 06:21PM
Kolas Registered Member #102 Joined: Thu Feb 09 2006, 08:15PM
about the PFC... if you use a resonant matched capacitor on the high side, lets say, you're drawing an arc. with the matched cap in series with the arc, wouldn't this act as power factor correction?
Sat May 10 2008, 06:37PM
Kolas wrote ...
Hi, I've done some research into this, based on the Resonant MOT arcs. This is the conclusion: As long as the resonant rise on the high side is enough to actually saturate your transformer, this "saturation current" is transferred to the primary winding, "opposing" the current from wall, so the current flowing through the primary decreases. So yes, resonant cap on the high side can be used as a PFC.
Actually, the current with my new resonant MOT supply is very low (~2A) with shorted output and goes up to 10A as the arc gets bigger and needs more power.
