  • Guests: 38
Need more power ! (transformer questions)
J. Aaron Holmes
Tue Apr 22 2008, 02:55PM
RogerInOhio wrote ...
I too have been craving more power and I am now working on a DC resonant charging Tesla coil that will use a 5kva , 7200 volt distribution transformer with a voltage doubler .
Buy the way if this thing is rated at 5kva continuous, dose any one know what the absolute maximum output would be. I have already had it loaded to 7 kva running the old coil and it doesn't even get warm.
The usual rule of thumb for pole pigs is 3-4x the nameplate rating for arbitrarily short periods. 7kVA is just scratching the surface of a 5kVA pig. Pole pig thermal ratings take into consideration the possibility of being under maximum rated load all day in direct sunlight on a 100+ degree (F) day. With the usually low duty cycles of TC operation and the relatively nice conditions of most garages (perhaps not in mid summer, but...) pole pigs can really be pushed hard!
Cheers,
Aaron, N7OE
RogerInOhio
Tue Apr 22 2008, 05:27PM
RogerInOhio Registered Member #1034 Joined: Sat Sept 29 2007, 12:50PM
Thanks Arron, If it can do 10 kva for Tesla coil use I'll be happy.
Roger
Andyman
Tue Apr 22 2008, 08:54PM
I think you would have to worry more about the stress on your capacitors and thermal stress on your spark gap than the stress on the pole pig.
MOT_man
Wed May 07 2008, 04:49AM
MOT_man Registered Member #1127 Joined: Mon Nov 19 2007, 12:08AM
Have a look a my 3.25" Tesla Coil running 1.8 kVA/ 12 kV NSTs
MOT_man
Wed May 07 2008, 05:23AM
Video file is located here - first upload was denied.
J. Aaron Holmes
Wed May 07 2008, 03:20PM
Where?
Proofreading one's own posts: Highly recommended wink
Cheers,
Aaron, N7OE
MOT_man
Thu May 08 2008, 01:40PM
Here is the video Youtube style....
J. Aaron Holmes
Thu May 08 2008, 03:35PM
MOT_man wrote ...
YouTube is Good smile
That's coolness. You've got some nerve running anything multi-kVA indoors, although as you say it's not tuned... I'd be too worried about the streamers "finding" things (e.g., appliances, wires in walls, ceiling lights, etc.).
You may find, too, that with >2kVA you've outgrown your <4" secondary.
Cheers,
Aaron, N7OE
MOT_man
Fri May 09 2008, 12:44AM
... I ran this coil off a 20A socket and used better wiring. The spark show was much more intense and the length of the sparks increase. I had an metal pipe in the ceiling that was being used as a strike target. It worked quite well!
MOT_man
Wed May 14 2008, 03:10AM
Ahha! I have better sparks now! Here is another video.....
