  • Guests: 59
Marx generator with 4kV SSNST
Tue Apr 15 2008, 09:27PM
Its build and running "great", since it do not have a trigger circuit there is alot of firing in the sparkgaps without a proper discharge.
NST delivers 4kV 20mA 20kHz and are put through 6 steps.
Its build with 1nF 7.5kV ceramic capacitors and 2x1M5 2.5kV resistors, and to rectify I use a string of 10 1N4007 diodes, which despite the warnings seems to work ok.
I can get a max of about 18 - 21 milimeter sparks, which is ok compared to the teoretical 24kV output.
my only beef atm is that the circuit aint too happy about triggering itself, on my NST I have quite long wires from the secondary (they are built into the transformer), and I can speed up the firing rate alot by strethcing the wires out in parallel, but they also get hot where they are too close.
text on my homepage is in danish, so I hope the above explanation will be enough :)
Pictures and schematics can be seen at my homepage: Link2
quicksilver
Thu Apr 17 2008, 02:50PM
Attached is an Excel spreadsheet for designing voltage multipliers. It's been productive for me to keep records of designs other than simple layouts or text files, etc.
]excel-voltage-multi.zip[/file]
Sat Apr 19 2008, 09:47PM
quicksilver wrote ...
Thanks for the spreadsheet, but could you please explain a couple of things to me
Vout is 4kV
Iout is 20mA
I got 6 stages
and output freq. is 20kHz
how do I know the ripple %? is that the 1.4 times Vout as mentioned in an earlier post? and what is the reg%?
quicksilver
Sun Apr 20 2008, 04:53PM
Seems you're going to have to add on to what's there. I just started it - as a way to maintain records. If everyone contributes a bit; it may eventually get pretty nice.
There is a pretty simple formula for percentages; I'll load it see.
Sun Apr 20 2008, 06:07PM
There seems to be some confusion here, lads. That Excel spreadsheet calculator is for Cockcroft & Walton type voltage multipliers, and can't be applied to a Marx at all.
Mon Apr 21 2008, 02:06PM
Harry wrote ...
that explains alot :)
quicksilver
Mon Apr 21 2008, 02:25PM
(Displays red face, kicks at the ground sheepishly) ahhh yea...that's right...ahhhh... oops.
Mon Apr 28 2008, 04:01PM
I ran the generator abit after I got home from work to film it, and it ran surprisingly well, giving 20mm sparks without much jittering.
Only got a canon ixus 70 so it aint too fancy with focus on film :(
youtube link -> Link2
