  • Guests: 52
M.A.D. (32)
12/14 M.A.D. (32)
12/15 marko666 (58)
12/16 Will T (16)
Which IGBT?
Hazel1919
Sat Mar 08 2008, 08:19AM
Hazel1919 Registered Member #1376 Joined: Wed Mar 05 2008, 08:31AM
Hehehe... I love you guys.
So, how would I go about grounding them? Through the RF ground? 240v Ground?
Thanks so much.
Plasma.
Hazel1919
Sun Mar 09 2008, 04:03PM
Yeah,, double post, sorry, sorry.
I have found the data sheet for the IGBTs I want to use here Link2 , It says that for Continuous Collector Current, it can withstand 55a and max forward current can withstand 220A!
Would this be good enough?
I am going to do a bit more reading.
Plasma.
Sun Mar 09 2008, 04:23PM
Just be sure if you use a TO-247 or similar package (as opposed to the SOT-227 types with much more thermal mass and lower thermal impedance) that you ensure proper heatsinking AS WELL AS proper thermal path from the component to ground.
Also, buy lots of them, as you'll smoke much more of these trying to get working that a larger IGBT.
Hazel1919
Sun Mar 09 2008, 05:06PM
yeah, they are the TO-47 type, so they will be fan cooled and have medium size heat sinks each, while having minimum resistance between them.
thank you EsterVoltResearch, more questions for you all later, plasma.
Hazel1919
Mon Mar 10 2008, 08:25AM
Ok, so the ground symbols on the circuit diagram by Ward must all be connected together?
How do I ground them?
Plasma.
Hazel1919
Fri Mar 21 2008, 08:47PM
Is anyone going to help me?
Ultra7
Sat Mar 22 2008, 12:35AM
Okay, Plasma, I'll bite.
Lets assume you have built an electronic circuit before.
Lets say that you built a simple light bulb circuit with a battery.
The red wire from your positive side went to feed the bulb.
The black lead coming out of the bulb you fed back to the negative side of the battery.
The black lead was your "Ground".
When you build a more complex electrical circuit, with both positive and negative voltages, your ground would be your zero volt reference.
Or, some good reading would be here.
and here. . .
I would recommend that if you don't know what "ground" is, then it would be beneficial to learn a few basics of electricity before attempting to build a tesla coil.
I would go get a book, one of the best is the ARRL handbook.
another good read is. . . .
And still better is. . .
Don't take this the wrong way, but really, learn the basics.
Sat Mar 22 2008, 01:53AM
Plasma wrote ...
Ok, I would also like to know how to build the Current Transformer?
I have no Idea.
Any help would be great.
Plasma.
Well, if you're lazy like me and don't want to build one, you can always buy one. Check out the CST-2A types on Digikey.com
Dan
Hazel1919
Sun Mar 23 2008, 10:01AM
Thank You, good bye.
