  • Guests: 56
Royer SSTC questions
flannelhead
Thu Apr 10 2008, 11:35AM
Arcstarter wrote ...
Place a transistor with the emitter on the negative supply and the collector on the negative side of the circuit. Connect the audio source's negative side to the emitter and positive to the base on the transistor.
Sounds good. BTW, do I have to use a BJT or could a MOSFET work too?
hvguy
Thu Apr 10 2008, 06:48PM
It is not necessarily as simple as just turning the negative rail ON/OFF. If you modulate a current feed inverter with the above mentioned method you will ring the series inductor on the positive rail. This will cause a large voltage to build up across it along with very high startup currents. Self oscillating current feed circuits (basically anything with an inductor in series with its input) general rely on both the switching devices to be on at startup. This means at the instant of start up the current across the series inductor will rise at a given rate (Vs/L assuming the input V is constant and your inductor does not saturate) until the circuit starts at which point the inductor load current will change significantly, causing the circuit to ring down at a low frequency. In normal operation this is harmless and allows the system to startup. However if you modulate the rail too quickly (like with audio or PWM) you will be switching on and off during this period of ring down. This creates all kinds of switching transits and will eventually kill something.
So bottom line is it will work, but if you are going to try and modulate that circuit with a low side FET make sure to pay attention to the current and voltage across it. The L of your inductor will, to some extent, control the max frequency at which you can “safely” modulate the circuit.
flannelhead
Wed May 14 2008, 12:38PM
Let's compare WaveRider's Royer driver and the Mazzilli ZVS flyback driver. Both can be used to drive a SSTC.
The main difference is that the Mazzilli circuit has a capacitor in parallel with the primary, and the operating frequency is determined by the LC circuit.
WaveRider's Royer circuit works from a center-tapped feedback coil and it tunes itself.
However, some people report just making a single center-tap primary for a SSTC and plugging it in an old Mazzilli flyback driver and voilà, it works! Link2
Has he just been lucky, or does the Mazzilli still tune itself somehow? I know it tunes itself for Zero Voltage Switching, but is the frequency always constant?
Wed May 14 2008, 05:08PM
The Mazzilli driver's frequency is set by the primary inductance and primary capacitor so it's as constant as the LC component's values. In order to run a TC secondary you need to tune the driver to the secondary fres by changing the primary capacitor/turns.
flannelhead
Thu May 15 2008, 11:46AM
That's exactly what I had understood.
It'd be pretty hard to tune a SSTC with that kind of a driver, especially if you only had one fixed value capacitor. Then it should be tuned with the primary, and that would go pretty complex because of the center-tap (or well, at least it would take a lot of time)
So I'll focus on WaveRiders Royer driver as it tunes itself and you don't have to worry about tuning it yourself.
Mathias
Thu May 15 2008, 04:33PM
Mathias Registered Member #1381 Joined: Fri Mar 07 2008, 05:24PM
Why not use his single fet driver ? If you read his end notes , he points out a couple of things about the royer design link
flannelhead
Sat May 17 2008, 01:05PM
Yes, I thought I could also give that circuit a try. One thing about the class E tuning capacitor: Which type do I need? Would some small-value ceramic caps do it?
Sat May 17 2008, 02:23PM
They might run warm, caps intended for some current will work best.
