  • Guests: 65
  • Members: 1
MMC versus a single Maxwell
Andyman
Mon Mar 03 2008, 09:21PM Print
I am considering buying one of these for my medium size tesla coil: Link2
How many volts AC would a capacitor rated for 35kV DC stand?
Also, has anyone had any experience with these in an mmc? Link2
They're digikey part BC2000-ND.
Do they look like they would work? They seem similar to these Link2 but are about 1/2 as expensive.
What are the advantages/disadvantages of using a single heavy duty cap instead of an mmc?
I will be using a 12kV 30ma nst as the power.
Logan Kennedy
Mon Mar 03 2008, 09:39PM
Logan Kennedy Registered Member #1103 Joined: Mon Nov 05 2007, 06:02PM
I can't answer your other questions, but let me say this.
wrote ...
If you loose a cap or two in an MMC one can easily replace the blown cap and be back in service, however with a single capacitor one cannot easily replace it. I see this as a major limitation.
For 95 dollars you should be able to build a decent MMC.
Hazmatt_(The Underdog)
Tue Mar 04 2008, 02:08AM
Another way of looking at the single capacitor is that film foil caps (depending on construction) have a limit of how many shots they will handle over their lifetime, say 10,000 for instance. For a SGTC 10,000 shots goes by real fast even at 120 BPS.
I have a bit of a hard time explaining this, so bare with me.
12kv NST X1.414 = 17kv peak
The ringdown of the tank will oscillate between +17kv and -17kv, this is 100% reversal rating and you will add the two magnitudes together for 34kv.
This is probably way too close to 35kv rating.
I would go for a 32kv rating maximum, which gives you peaks of 16kv for each ringdown half cycle, and 16kv * .707 = 11KVAC on your NST for safety margin.
Tue Mar 04 2008, 02:16AM
Is it used? a lot of caps like that on the internet have been used in research marnax generators
ShawnLG
Tue Mar 04 2008, 02:46AM
Those Maxwell caps are only rated for 15% voltage reversal. They will eventually die in TC duty.
Coronafix
Tue Mar 04 2008, 02:52AM
And when they die, it's oil everywhere!
Shaun
Tue Mar 04 2008, 04:25AM
I'm wondering how I ever managed to run an SGTC based on a 15kV/30mA NST with an MMC only rated for 22.4kVDC...
Its made of these:
It still works to this day, and the arrangement is 7 parallel strings of 14 in series for a total of 98 capacitors. If you order 2 more you reach the 100 piece price break and get all of them for $40.
The spark length with air blown static gap was about 30 inches before the secondary burned.
I guess these caps are made with a good amount of safety margin in their voltage rating...
Tue Mar 04 2008, 06:23AM
ShawnLG wrote ...
Not necessarily...
The name of the game is derating.
35kV and 15% reversal coresponds to 35+(35*0.15) = 40kV
A tesla system has, say, 90% reversal, so with 40kV to do good with, the peak charging voltage cold be as high as 40/1.9 = 21kV.
You can call it a 21kV cap, rated at 90% revesal.
A transformer rated at 21/1.41 = 14,9kV would then allow you to utilize the full potential of the cap, and as such, it is the perfect match for the odd neon transformer.
But you will only have the safety margin that`s designed into the cap itself.
Cheers, Finn Hammer
Tue Mar 04 2008, 12:48PM
Finn Hammer wrote ...
ShawnLG wrote ...
Not necessarily...
Cheers, Finn Hammer
Can someone explain me rightly what voltage reversal really is?
I thought is was the maximum percentage the voltage can ring under zero after cap was charged to it's rated voltage?
I still don't understand what significance this has, how in a world can this cause the cap to fail.
Only explanation I got is that high voltage reversal would cause high mechanical stresses to dielectric. (how can that be a problem?)
What does this have to do with the AC voltage rating of the cap? Why are AC ratings always so much lower than DC ratings?
GeordieBoy
Tue Mar 04 2008, 01:00PM
It's all to do with charge trapped inside the dielectric of the capacitor I think Marko. This trapped charge causes additional stress on the dielectric when the plate potential reverses.
