  • Guests: 64
RoV IW3IPD (63)
01/12 RoV IW3IPD (63)
Is a NST lethal?
Ken M.
Mon Mar 03 2008, 12:10AM
Shall I just sum it up for everyone? Wether its lethal or not, DO NOT try to connect it to yourself or use it as a prank or a dare!
lpfthings
Mon Mar 03 2008, 06:27AM
lpfthings Registered Member #1361 Joined: Thu Feb 28 2008, 10:57AM
Yep, good advice Ken M. I hate shocks, i cant stand how people even shock themselves on purpose with those barbeque ignitors.
Tesladownunder
Mon Mar 03 2008, 08:18AM
When I do public shows, one of my more popular and interactive segments is when I offer people free electric shocks. "Yes, Sir and Madam, despite rampant inflation some things in life are still free."
I use my Candy Box HV unit and demonstrate the 1 inch sparks to my arm.
Some people shrink back, others volunteer. What I find interesting is that some people come back more than once. It's a bit like overcoming your fear is a reward in itself. Maybe bungee jumping has a similar psychology.
TDU
lpfthings
Mon Mar 03 2008, 11:42AM
lol, i just plain hate being shocked. Its happened to often amazed I'm sue there would be a few risk-takers that would do it. Though the high frequency affects alot in what you can feel, 50hz hurts!
Tue Mar 04 2008, 02:30AM
absolutely dangerous!if you get jit hard and dont die you could become mentally retarded.i have been shocked to before.i will not tell you with what cause you wont belive i am sitting here now and i may get kicked off of the forum but lets just say most people would likely die.im sure i should have.i was numb and could not move correctly for awhile.i shot back so hard i would have probably broken something if i had hit something hard.so don't underestimat a few 100's of watts of electricity.you get shocked across both arms you will likely die.
Simon
Tue Mar 04 2008, 02:31AM
Many times when I was a noob I made something safe (current-limiting or whatever) and then had an accident with it some other way. I remember the time I burnt myself on a current-limited arc. Also, the loss of control from a minor shock is a common cause of more major shocks (e.g. jerking back and hitting something else).
Tue Mar 04 2008, 02:42AM
That is one of the more common causes of electrician deaths. The shock only causes you to loose control but the fall off the ladder or onto machinery is what does you in. I agree with the other posts, it doesn't matter if it can kill you or not don't touch it either way.
Tue Mar 04 2008, 03:42AM
Always treat all high voltage devices with respect and treat them as lethal.
High voltage DOESN'T kill.
Complacency KILLS!
As the high voltage safety instructor in a company with over 5000 people, i teach to respect any voltage over 30V as potentially hazardous.
