  • Guests: 47
Is a NST lethal?
Zum Beispiel
Sat Mar 01 2008, 03:32PM
Yes, they can be lethal. While most people will survive a shock from a NST, some might not be as lucky. It all depends on a lot of things. Better not take any chances.
Bjørn
Sat Mar 01 2008, 04:10PM
Ventricular fibrillation happens as a function of current and time, the formula and some other information is in our wiki: Link2
Different people react differently so the formula is only valid as an average for a large sample of people. What kills one person instantly may be harmless to another person.
To answer the question, yes it may kill you under certain conditions. Passing the current from one finger to another on the same hand will not kill you directly if you are healthy. It may cause you to fall face forward over the PSU where you will be slowly fried.
lpfthings
Sat Mar 01 2008, 10:26PM
lpfthings Registered Member #1361 Joined: Thu Feb 28 2008, 10:57AM
Ok, thanks for the replies guys! Once i make a tesla coil/good jacobs ladder the NST will be mounted in some sort of clear box, along with any of the other HV parts. Just a quick question, if you were wearing shoes, and you got shocked from say, only the HV + in your finger, would you feel anything apart from heat? Would it even arc to you?
Ultra7
Sat Mar 01 2008, 10:44PM
Lets tell this one. . .
I got juiced by probably less than half of my NST's voltage (15000/30) because I was tuning the coils safety gap with a variac.
I would turn it up to full, and note for the gap firing, then dial it down to 0 to make adjustments.
Well, I got complacent, and wasn't minding my "cobra" well enough.
I had only turned the variac down till the coil wasn't firing, not till I had zero volts, and gave my safety gap a twist.
I think if I hadn't recently gone to the restroom, I probably would have pissed myself.
I bit clean through my tongue, as well.
I was wearing good shoes, and luckily had one hand on my hip.
Now I have a variac with a power off button, and I unplug everything before I even think about touching anything to do with the transformer.
Wirenut
Sat Mar 01 2008, 10:48PM
Wirenut Registered Member #141 Joined: Sat Feb 11 2006, 01:14PM
Yes, once the voltage gets high enough, the capacitive current is enough to severely shock you - you don't need to be grounded. I have been shocked by touching an insufficiently insulated wire from a 9kV NST. I was "floating" - shoes on, isolated from ground, not touching anything else, etc., and it was only half of the NST's voltage.
teravolt
Sun Mar 02 2008, 06:08AM
to whom it may concern MOTS are more leathal because they can supply up to 300ma at 2kv. it only takes ony 20ma to kill. safe coiling
Sun Mar 02 2008, 09:31AM
teravolt wrote ...
actually up to 2 amps if not current limited dead
lpfthings
Sun Mar 02 2008, 09:45AM
wow, ok. I have made a big perspex box, and im going to make a nice big jacobs ladder in there, i dont wanna take any chances.
Zum Beispiel
Sun Mar 02 2008, 10:45AM
And that's the way it should be smile If you learn the proper safety procedures with something relatively safe like a NST, you'll be safe when you start working with more dangerous things like MOTs, PTs, pole pigs and the like.
Sun Mar 02 2008, 10:56PM
You guys have said most of the info I was going to share but what they told me in trade school (electrician) was that it take 10ma right through the heart to stop it from pumping and that it takes about 60ma from arm to arm to get that 10ma needed to stop the heart. But that is all at 120v, so you can safely assume that for an HV source 10ma could be enough to kill you if you were unlucky enough to stick to it.
