  • Guests: 62
01/13 si2030 (62)
Flyback Arc Contest
first  2 3 4 5
Sat Mar 25 2006, 01:50PM
The IR2153 can supply peak about 300mA, thats not much. For medium gate capacitance fets, I think it will not go much above 50kHz.
the_anomaly
Sat Mar 25 2006, 03:29PM
the_anomaly Registered Member #19 Joined: Thu Feb 02 2006, 03:19PM
Here is one if my flybacks driven to its limit. Unfortunately the camera decides to run out of memory the second before it self destructed. I can feel the arks heat about 2 feet away shades ZVS driven flyback
Sat Mar 25 2006, 04:24PM
Hm, i downloaded and I cant run the film. RAD says there is a error in it and wmp asks codecs (cannot be true as I can surely run AVI files)...
c4r0
Sat Mar 25 2006, 07:12PM
c4r0 Registered Member #151 Joined: Sun Feb 12 2006, 02:53PM
Open it in 'virtual dub' (download link: Link2 ). Then select 'direct stream copy' in video options and 'save as AVI'.
Kolas
Mon Mar 27 2006, 05:04AM
Kolas Registered Member #102 Joined: Thu Feb 09 2006, 08:15PM
haha! no wonder this flyback driver is so sucessfull:
DR tanks really allow the current to flow
has anyone tried incorperating Dual resonantcy into the ZVS driver?
anyway i think DR primaries are the way to go give it a try wink
Mon Mar 24 2008, 07:39PM
I found this thread while browsing some old stuff. who said there wont be any more arcs tongue Here is one, the flyback didn't get hot at all running at this power but I couldnt put in more as the output voltage was dangerously high.
1206387310 152 FT393 Arcsandsparks
Lets see some sparks and arcs! Anything, high voltage, high current, or with homemade coils!
Do you think it's a good idea to start a new thread in the HV section where people could post any sparks and arcs, not limited to flybacks? Every HV forum seems to have such thread and I think it's a good and interesting idea wink
J.M.
Mon Mar 24 2008, 09:28PM
My god Jan that's amazing. amazed
While experimenting with flybacks and resonance points with my offline driver I could hit a point at ~200kHz where the output would suddenly increase by a tenfold. All I was ever able to do is get one crappy photo before the over-current tripped. I also tried getting some good arcs, but they're nothing compared to what you can do with flybacks. I've only ever had monitor flybacks to work with however. I would estimate the length of the spark to be around 10cm with both sparks together in the second picture.
1206393825 95 FT393 Oilsunkflybackarks 1206393825 95 FT393 First Encounter
Ken M.
Mon Mar 24 2008, 09:32PM
"Sprite The thirst quencher! Also with Electrolytes!"
Mon Mar 24 2008, 09:44PM
Nice Uzzors, i never thought that there would be such high frequency point where the output would so dramaticlly increase, I always observed it to decrease with increasing freq. (higher frequency and same inductance> lower output).
Do you think its a good idea to start "Arcs and sparks" thread or would it get forgotten after a few posts as this thread originally did?
Mon Mar 24 2008, 09:57PM
I'm not sure, personally I don't have anything else worth posting. neutral I built a resonant MOT setup like you detailed in a thread, but my camera just saturates so no pictures. You might want to throw in your best pic just so it's here, those arcs are the biggest I've ever seen from common parts.
Other than that we'll just have to wait and see! Maybe this thread could become a sticky like the post your Tesla coil here. It's also fun to see how and with what people have made various sparks and arcs.
first  2 3 4 5
