  • Guests: 55
CT2 (37)
Josh Johnson (46)
01/21 Banana Man (41)
01/21 TheAnomaly (13)
01/23 GimpyJoe (36)
Rfi filter?!?
Spedy
Tue Feb 05 2008, 11:57PM
Spedy Registered Member #964 Joined: Wed Aug 22 2007, 12:39AM
lol, ok. I'll try running it w/o any sort of filtering. I have a little ferrite bead thingy that went around a cord from something I can;t remember taking apart... Maybe passing the Gnd line thru this a couple of time might work/not make it worse?
Andyman
Wed Feb 06 2008, 05:51AM
What about for a ground, using maybe 6 shorter rods, about 3 feet long and connecting them all up together. The coil will "think" it's actually one huge ground rod.
Or get a hollow copper pipe and attach a water hose to the end and on full blast, push it down. The water would act like a drill and push all the dirt away.
