  • Guests: 67
MMC Design
Wolfram
Fri Jan 25 2008, 09:30AM
I've heard that connecting caps between strings is not recommended, as it can interfere with the self-healing function of the caps. I don't remember where I read it, so I don't know if it's trustworthy information.
Dr. Slack
Fri Jan 25 2008, 12:27PM
This is a fairly fundamental question in MMC design, I've not found any authoratative guidance with a quick google, or a visit to the usual suspects. I only suggested paralleling as a means to reduce the number of resistors, which is not a smart economy if it causes the cap bank to fail earlier. My MMC is paralleled units BTW.
Given that the healing mechanism consists of the cap vapourising the bit of electrode feeding the failed section, I would have thought that the extra energy available in the parallel caps would have assisted that process.
The value of the healed cap drops slightly. This causes that cap to take slightly more than its share of the applied voltage due to potential divider action of the other caps in the string, making it more likely to fail in the future and causing a runaway if the cap was being run right at the limits. It seems to me that caps directly in parallel will reduce this effect. That's a second vote for direct paralleling.
However, there may be a "killer" reason why paralleling is bad, which outvotes the two consideration above? I suppose that if the parallel connected caps "assist" the electrode vapourisation too well that could splatter the cap being healed.
There's less dismantling to do to identify a single failed cap with only series strings. With parallel strings, an o/c failed cap will probably take its parallel connected brothers with it due to overvoltage. BTW, what is the dominant failure mechanism for polyprop cap failure?
How about updating our Wiki MMC entry if we come to any good conclusion?
<edit> A lot of the manufacturers' literature on self-healing majors on the metalised types, whereas we prefer to use film/foil for the higher current handling in TC use. Metalised need much less energy to zap the electrodes than a foil type. Many make their electrodes segmented to introduce "fuses" deliberately between the sections to control the self healing action better. Just some further complicating considerations. </edit>
H~Tank~V
Fri Jan 25 2008, 01:05PM
H~Tank~V Registered Member #1253 Joined: Tue Jan 22 2008, 02:06PM
Ok, so 8 .068uF caps in series will give me .0085uF, this is 1.5 times over resonance. So if I put a 22M Ohm resistor in parallel with each cap I should be ok?
Sorry to the mods for being new here and not knowing the the "rules", but their is no need to be a douche.
Fri Jan 25 2008, 05:03PM
Film/foil caps don't self heal. If they do, it's because they have a metallized film conductor internally, which all higher voltage film/foil caps do. (They are two sections in series, and the metallized film connects them together.)
This has all been discussed in agonizing detail on the Pupman list more times than I can remember, so a browse of the Pupman archives may bring up more information. I also remember someone recommending not to connect self-healing capacitors in parallel, but don't know if it was authoritative.
BTW, sorry about the 400 pixel thing, but it's in the rules you agreed to when you joined up, and calling me a douchebag doesn't help. (Neither does using their instead of there.)
