  • Guests: 65
MMC Design
H~Tank~V
Thu Jan 24 2008, 02:02PM Print
H~Tank~V Registered Member #1253 Joined: Tue Jan 22 2008, 02:06PM
I've come up with an idea for an MMC for my coil. Before I run out and spend my money, I just wanted to make sure it was "up to par". Here is a pic of my design. All the information is on it. If I am missing anything please let me know.
Thanks!
MMC
Mod Edit: the dilithium crystals can nae take more than 400 pixels
Kizmo
Thu Jan 24 2008, 02:49PM
It looks like pile of capacitors in series-parallel.. which is called MMC :)
What kind of transformer you are planning to use?
H~Tank~V
Thu Jan 24 2008, 02:59PM
Here is a pic of the transformer its 15000V @ 30mA.
Transf
Mod Edit: See above. Edit this post to see how to post an oversized image properly
Thanks!
Dr. Slack
Thu Jan 24 2008, 04:25PM
You might be missing a bleeder resistor across each cap. If you connect all 3 strings at all the nodes, then you only need one per 3 parallel caps.
If there's any unbalanced leakage on the caps, it prevents a steady build up of charge on one leading to over-voltage, and of course it runs the charge down at the end for safety.
Coronafix
Thu Jan 24 2008, 11:04PM
Your value is a bit too close to resonance. You should have about 1.4-2 times the resonant value otherwise the voltage rise on the bank may go to high exceeding the rating.
H~Tank~V
Fri Jan 25 2008, 02:52AM
Ok, so changing the cap's to .022uF will give me .00825uF which is about 1.47 times more than resonance.
Is that the idea for the bleeder resistors?
1
Mod Edit: Is it Noob season already?!
Andrew H
Fri Jan 25 2008, 03:41AM
Andrew H Registered Member #1198 Joined: Sat Dec 29 2007, 05:39AM
Generally people use the 942C series capacitor from CDE. They have better specs for use in TC service. Also using a higher value cap (.1-.15uF) will cut down on the number of caps you need (and generally the cost).
Coronafix
Fri Jan 25 2008, 07:07AM
If you use 8 x 0.1uF that will give you 12.5pF
therefore cutting the cost by a third.
Herr Zapp
Fri Jan 25 2008, 07:52AM
Remember that the peak output voltage of your transformer (if you limit the input voltage to 120) will be over 21,000 volts (15,000 RMS volts X 1.414). Your bleeder resistors will need to withstand this voltage, so use a resistor across each capacitor to allow the voltage to divide across the maximum number of resistors. Also, use special resistors rated for high voltage use. The Vishay VR-37 (.5 watt) metal film resistors are rated for 3500 volts, vs 500 volts for standard metal film resistors. The VR-37 resistors cost around $0.10 each, so the cost is insignificant.
Dr. Slack
Fri Jan 25 2008, 08:19AM
No.
The centre terminal of each cap pair is floating, so charge could build up on that. In addition, the ressitors need to withstand 2x cap voltage, so you need to start fiddling with series strings, or expenzive resistors.
Try this (the configuration, not the 1k/1n default values!). Even a value as high as 10meg would dissipate 1 watt at 3kV, so you might be better off with 22meg or 47meg. These still give seconds for dumping the charge when you've finished.
