  • Guests: 57
OnFire (64)
01/24 OnFire (64)
01/25 Evgenij (60)
01/25 Our Finest Hour (64)
project "long Sparks"
Linas
Thu Jan 24 2008, 09:14AM Print
Hi all
I started to build Full-bridge Pll AM SSTC cheesey
First make PCB
Thet Put all parts together
Next week, i make full-bridge circuit, and then sparks :)
PLL driver not working, i use 74HC4046 PLL, is it same as CD4046 ? confused
1201166093 1143 FT0 P1360158
1201166093 1143 FT0 P1360159
1201166093 1143 FT0 P1360166
Wolfram
Thu Jan 24 2008, 09:35AM
Very nice and clean board design, looks good.
Thu Jan 24 2008, 10:37AM
Very nice board indeed. You didn't happen to feed 12V to the 74HC4046 did you? 74HC chips are for 5V max.
Thu Jan 24 2008, 10:38AM
The difference is that a 74HC4046 can only run off 5V supply. 15V will kill it.
flannelhead
Thu Jan 24 2008, 01:04PM
The 74HC4046 chip should be used if the resonant frequency is much higher than 2 MHz. Otherwise a normal CD4046 should be just fine.
Linas
Thu Jan 24 2008, 03:26PM
everything works good, pll was bad smile
I add wave forms with and without load (load is 100nF F 300KHz )
1201188412 1143 FT37926 P1360168
1201188412 1143 FT37926 P1360176
Linas
Fri Jan 25 2008, 08:08AM
How to protect CD4046 from static energy ? i kill 3 CD4046, just 74HC4046 is working, but not very well :(
Fri Jan 25 2008, 03:22PM
Don't rub your wool socks on the carpet. Seriously, I can't recall having a single ESD death in the last 3 years, are you sure that's the problem? Use a grounded wrist-strap and sit in one place while working with sensitive chips, that should eliminate most problems with static.
Logan Kennedy
Fri Jan 25 2008, 05:33PM
Logan Kennedy Registered Member #1103 Joined: Mon Nov 05 2007, 06:02PM
That is a very clean board etch!
How did you create it? I've never had any real luck with etching pc boards.
I can't wait to see this project fully completed!
Linas
Sat Jan 26 2008, 04:51PM
74HC4046 is very sensitive, current transformer can "feel" my hand amazed
I am thinking about interrupter with overcurrent protection, is it nesesere in SSTC ?
Because i very frequently kill mosfet's cry
Using this driver with my tesla coil secundary and primary connected to this bord, it's generate ~2cm spark, so with 311V will be 25 greiter amazed
