  • Guests: 48
building my first sgtc
first  3 4 5 6
Ultra7
Fri Feb 08 2008, 05:14AM
Your NST should be in parallel with the safety gap.
Here look at this.
See the Terry filter has a safety gap as part of the circuit.
NST Hot 1 to one side of the gap and gap ground
NST hot2 to the other side of the gap and gap ground.
NST Ground and RF ground on the same bus.
SilentPhoenix
Mon Feb 18 2008, 02:48PM
SilentPhoenix Registered Member #1258 Joined: Wed Jan 23 2008, 11:52AM
sorry for being away for a while guys, i had a testweek in school so i had to study a lot... after my last test on friday i continued my tesla project. i now have two vacuüm cleaners which i will use to ventilate my primary gap. i also finished my beer bottle cap. now updated to 24 bottles in a beercase.
i'm gonna make a primary coil and gap now and take some pics of my new stuff :)
SilentPhoenix
Fri Feb 22 2008, 04:47PM
hi guys, i fixed my new primary gap and made a vid. could you check it out and give some feedback about how it's running?
i had kind of a hard time getting it to spark all three electrodes and not just one... any advice?
ArcLight
Fri Feb 22 2008, 05:52PM
ArcLight Registered Member #341 Joined: Thu Mar 23 2006, 07:41PM
Put the gaps in series rather than parallel.
Regards, ArcLight
Andyman
Fri Feb 22 2008, 07:15PM
On my mini coil, my spark gap is inside a short segment of gray pvc pipe and on either side are hoses of the same size running off to the sides. On one of the hose ends, I have a high power leaf blower and the results are a HUGE improvement from the weak shop vac exhaust. The hoses allow me to have the blower far enough away from the coil so it doesn't drown out the sound of the sparks, and the powerful blower lets me get away with using a single gap. The gap stays cold because of the massive amount of air being moved across the electrodes.
Ultra7
Sat Feb 23 2008, 01:43AM
SilentPhoenix
Wed Feb 27 2008, 11:51AM
new vid of the series spark gap:
also updated the pics link i posted earlier.
i'm now waiting for the plexi to build the case for my spark gap and i'm gonna build the grounding circuit now and then it should be ready to test :D
Cain
Wed Feb 27 2008, 12:23PM
Cain Registered Member #624 Joined: Tue Apr 03 2007, 07:50AM
starting to look good... but i dont like the idea of adjusting the gap with the NST on, not a good idea
Coronafix
Wed Feb 27 2008, 12:54PM
When I suggested the bolts in wood, I actually meant something as simple as this.
Model
SilentPhoenix
Wed Feb 27 2008, 02:10PM
i can change it again, no problem. would that be more effective? and how would i be able to adjust the gap size? or is that unneccessairy? (i would be amazed if i spelled that right l0l)
first  3 4 5 6
