  • Guests: 46
Seeking to hire someone to fabricate Zamboni HV battery
IntraWinding
Sun May 02 2010, 02:20PM
Apparently the Oxford Bell batteries were sealed with molten sulphur.
I bet that contributes some sulphur acids, but strange to think of it contributing both conductive acids and acting as an insulator.
Perhaps the sulphur releases sulphur dioxide which forms acid with the moisture in the paper whilst the solid sulphur remains non conductive.
But there again, I'm reminded of Compact Disc Bronzing Link2 and the problems acid paper causes libraries Link2 , but both those issues suggest old paper contains enough sulphur of its own to not need the extra provided by a coating. And apparently "cellulose itself produces formic, acetic, lactic and oxalic acids."
I wonder if someone makes a range of metallised cigarette papers? If they sell a silver and Bronze variety you could work up a technique for punching out discs in their thousands and start experimenting smile Otherwise, some other pair of metallised papers must be out there.
Sun May 02 2010, 02:31PM
There's nothing in the least bit mysterious about 'Zamboni' piles, which will supply current until all the zinc is oxidized. It is not 'electrostatic' at all, but electrochemical in nature, and is wholly dependent on the standard reduction potential difference between the substance in the cell being reduced, and the substance being oxidized. It is only 'dry' in the sense that it did not have liquid sloshing about, in the way of Leclanché cells.
Portable equipment of the Thermionic Age often used HT batteries to supply 150V or so for the valves, and in the early years of atomic research, batteries consisting of thousands of individual cells wired in series were often employed when kilovolts were required on tap in the laboratory.
Finally, effective treatment for Zamboni's piles was probably not available in the early 19th century.
radiotech
Sun May 02 2010, 04:47PM
A use for this device might be discovery and testing hitherto unknown uses of paper with the object of improving the printability and/or mechanical aspects of fibre based structural members.
It is amazing that the non uniformity of paper makes every bit different than every other bit made.
IntraWinding
Sun May 02 2010, 10:33PM
I remember as a child saving up and buying an Ever Ready 90V battery that my nearest bicycle shop had on sale for people who still had valve radios, something like this Link2
I was worried that despite the hight price it might have sat there for years and be useless, but it was fine. Made really nice little arcs between copper wires!
Whatever the chemistry in that Zamboni battery is, it has an amazing shelf life. I doubt there'd be much juice left in a Duracell after 160 years!
Alan
Mon May 03 2010, 03:16AM
IntraWinding wrote ...
I remember as a child saving up and buying an Ever Ready 90V battery ...
Me too. Found a 90 volt dry cell in stock at J&H Outlet (electronics and surplus) about 10 miles from home by three-speed bicycle. Needed it for some neon glow lamp blinky circuits.
