  • Guests: 39
GDT problems
Andrew H
Wed Jan 09 2008, 07:01AM Print
Andrew H Registered Member #1198 Joined: Sat Dec 29 2007, 05:39AM
I constructed a GDT for my first SSTC last night. I made it by wrapping CAT5 cable around a ferrite torrid (in the fashion that Steve Ward used on his DRSSTC1). Here is a picture of the GDT:
1199861342 1198 FT1630 Gdt
I know the leads are a bit long and that is probably negatively affecting performance but I don't want to chop them down until I build the H-bridge and know exactly how long they have to be. I connected it to a set of TI driver chips (UCC37321 and UCC37322). A 555 timer provided the input to the driver chips. Here is the output relative to ground:
1199861342 1198 FT1630 Gdt Output First Test
The output has a huge over/under shoot (when not even connected to a MOSFET!) and the output droops substantially. I'm going to try removing the outer case of the CAT5 and winding the wires in a polyfilar bundle. Hopefully that will lower leakage inducance and help the output.
What else might help my GDT produce a cleaner output?
Wed Jan 09 2008, 07:22AM
You need to at leat attach a dummy load to the output (like a 1nf cap or so, make it about the same size as the gate on your transistors) to see what is happening. Also, to get rid of the spikes the traditional route is to add back to back zener diode across the output.
Wed Jan 09 2008, 07:30AM
Be sure to twist the primary and secondary leads together to lower the wiring inductance. Be sure you arent saturating the thing! The droopy-ness of that waveform looks highly suspicious.
If you really followed the same technique i used, the coupling is very high. But it can be difficult to fit enough turns on a smaller core to avoid saturation, so sometimes its best to only use the number of wire strands that you absolutely need.
Andrew H
Wed Jan 09 2008, 08:32AM
For testing I am using one wire for the primary and one for the secondary (1:1 ratio). Other than those two wires all the rest of the wires in the CAT5 cable are not connected to anything. I don't think that I could be saturating the core that easily. How would I be able to tell if I was saturating it?
I tried attaching a small ceramic capacitor across the output but it didn't change anything.
Kizmo
Wed Jan 09 2008, 10:40AM
Take a look here:
ragnar
Wed Jan 09 2008, 10:41AM
wrote ...
Actually, with only four or five turns, I'm pretty sure you'd be close to saturating the core at this considerably low frequency. The "drooping" which Steve Ward refers to is a good indicator that something's wrong; double your turncount.
Wolfram
Wed Jan 09 2008, 11:54AM
Am I the only one that notices that his duty cycle is way off? Having a duty cycle other than 50% is an easy way to saturate the core if you don't have a DC blocking cap before the GDT. Either way, get the duty cycle as close to 50% as you can, this is going to improve the waveform too. I agree with many of the others in this thread, you seem to have too few turns on the GDT. Try to connect two windings in series for 8 turns.
Wed Jan 09 2008, 12:02PM
You need more turns. Double your turn count and go from there.
Wed Jan 09 2008, 02:00PM
You guys all just read andrew's mind for the frequency (which he didn't mention anywhere)?
And yes, nobody notices anything wrong about duty cycle?
Andrew, you need closely 50% duty cycle input to GDT, and use a DC blocking capacitor in series with your driver output, otherwise small DC caused by uneven duty cycle saturates the core.
7474 bistable can give you good 50% duty cycle output.
I don't know why are you guys panicked for saturation so much, unless we are in audio frequencies here.
I used 6 turns on about 2x smaller core for my DRSSTC at 100kHz, and it worked very well.
If in doubt just use datastream's site.
ragnar
Wed Jan 09 2008, 02:42PM
wrote ...
Single-turn GDTs are acceptable at insane frequencies. It thereby goes that two-turn GDTs are appropriate at insane/2 frequencies, and a four-turn GDT is only appropriate at insane/4 frequencies.
Since this is Andrew's first coil, I safely assume that the frequency is not more than quarter-insane. Therefore, he should use more than four turns on his gate-driver transformer.
Hence the summarized advice:
double your turn-count.
tweak the 555 until the duty is much closer to 50%.
use DC-blocking caps in series with the GDT primary if not already doing so.
1199889747 63 FT37172 Lowind1
1199889747 63 FT37172 Lowind2
