  • Guests: 41
RoV IW3IPD (63)
01/13 si2030 (62)
Jacob's Ladder: Does electrode diameter make any difference?
Thu Mar 16 2006, 02:25AM
I used 1/2 inch copper for my mot stack JL, it was a little hard to work with but once it was set up it worked perfectly and consistantly. I woudl say as lonf as you don't go too small you are ok. I didnt have any special bending at the top of the ladder and it still worked fine.
1142475921 53 FT3700 Plainladder
I put 2 screws though each pipe and used those to set the seperation of the pipe. I also use a 10M resistor at the bottom of the pipes to initiate the arc.
