  • Guests: 45
A.M SSTC
f0rd
Fri Jan 04 2008, 06:24AM Print
f0rd Registered Member #1209 Joined: Fri Jan 04 2008, 06:07AM
Afternoon, right first things first, I am not a coiler, nor am I an electrician.
But I am doing a project at present on plasma speakers and high quality audio reproduction, I have already covered the early for runners such as the Ionophone, Plasmatronics et al.
And this has led me onto Audio-Modulated Tesla Coils, I have been doing some research so far onto modulating the SSTC, that’s how I found this forum from stevehv’s blog.
So far I have got ‘Amplitude Modulation’ and ‘Pulse Repetition Frequency Modulation’, of course did the went to wikipedia to see what other forms of analog modulation there is.
Essentially what I am asking, what other methods of audio modulating an SSTC have been implemented that you, or can be used, advantages/disadvantages?
Any information or point in the right direction would be grateful.
Thanks
Fri Jan 04 2008, 11:05AM
I'm currently trying to get a drsstc working with FM modulation. It's basically a class-D amplifier. The feedback signal goes trough an integrator to get the triangle reference waveform. This wave gets FM modulated by using a high speed comparator. This FM modualted signal is fed to the gate drive circuit which drive a halfbridge.
Fri Jan 04 2008, 11:20AM
Well, the most popular methods are AM modulation and PWM (pulse width) modulation with PWM modulation being the most common and efficient.
AM modulation is actually the best, especially if done on the high side (modulating the power supply) as it will provide the best sound quality. But PWM modulation (i.e. modulating the gate) is best due to ease and high efficiency, albeit at a degrade in audio quality.
Dalus wrote ...
Not sure how FM modulation would work as you would effectively be detuning the coil during operation. However, it sounds from what you are describing is not FM modulation, but just PWM modulation.
Fri Jan 04 2008, 03:32PM
PWM modulation causes fm modulation
'This is also an FM, or frequency-modulated system -- the varying pulse-width translates into a varying frequency. And it is the core principle of most Class-D switching power amplifiers. The analog input is converted into a variable pulse-width stream used to turn-on the output switching transistors. The analog output voltage is simply the average of the on-times of the positive and negative outputs. Pretty amazing stuff from a simple comparator with a triangle waveform reference.'
I found it in an article at Link2
Fri Jan 04 2008, 05:50PM
Dalus wrote ...
Uh, no. PWM does not frequency modulate the signal. PWM merely varies the pulsewidth of the carrier signal. Input an analog single into the comparator and compare with a sawtooth, and you'll get out a varying pulsewidth signal (of the SAME frequency) vs. the amplitude of the original sampled analog signal.
FM modulation is completely different. Its basically where you are modulating the carrier frequency.
See article below:
http://en.wikipedia.org/wiki/Frequency_modulation
Fri Jan 04 2008, 08:10PM
Steve used FM modulation on PLL: Link2
FM modulation of input causes AM modulation of coil output.
CT2
Fri Jan 04 2008, 08:59PM
I used Steves PLL for an audio modulated coil. It works pretty good, although I haven't tried any other types so I don't have much to compare too. I have a video of it on youtube; Link2 . It is fairly clear (a little distortion, depends how high you have the volume cranked on the input signal, an ipod) and it is very loud considering how small the coil is, I can hear it on the top level of my house and the coil is in the basement (3 levels).
teravolt
Sat Jan 05 2008, 04:12AM
that paper is interesting and I atempted to repair one of those 2000w power audio bass amps. The method they use is to combine PWM with the audio input to charge a set of caps baisicly. the problem is that the load is fixed and not dynamic like a DRSSTC. If a DRSSTC load is used it mite take some clever electronics to enshure the cap voltage tracks with a audio input
Sat Jan 05 2008, 12:20PM
teravolt wrote ...
Could you post the circuit diagram of that amplifier, I would like to try as many methods of audio modulation. I'm still in the breadboarding phase so it will be fairly easy to swap things around. And hear what it sounds like.
f0rd
Sat Jan 05 2008, 03:23PM
Thanks for the help so far guys, another question MOSFETs vs Spark Gaps, I take it MOSFETs are preferred due to spark gaps creating quite a bit RFI and are noisy?
And from what I am reading, am I correct in stating SSTC don't need a large transformer? Well large as in 15 kV.
