  • Guests: 53
CM300/CM600 High Power Gate Driver - Complete Design with PCB
Coronafix
Fri Dec 21 2007, 10:13PM
There are some tutorials at the bottom of this page: Link2
Sat Dec 22 2007, 10:37AM
"Love is good, but not as good as a Spice simulation." - Sid Vicious
Microsim/Orcad/Cadence/whatever "PSpice" doesn't work quite the same as Electronics Workbench, or the other newbie packages where you get virtual test equipment to hook up to your circuit.
All of the node voltages and currents get calculated anyway, so in the results viewer (used to be called Microsim Probe, not sure what it is now) you just press the Insert key, and it pops up a dialog of things that you can plot. The power of this is that you can also type in math expressions, so to see the gate voltage of the top transistor in a halfbridge, you might enter V(M1:G)-V(M1:S) or whatever.
I believe you can also drop voltage and current probes in the schematic editor and it'll add the appropriate trace to the plot in Probe, but I never used that feature.
I seem to remember you press F11 to simulate, too. I can't really remember as I changed to LTSpice a while back.
Reaching
Sat Dec 22 2007, 11:22AM
a other nice software i use for my simulations is called swcad or switcher cad. its freeware and spice based. its much more simple than pspice and cause i never really understood pspice, i use this software instead.
Sat Dec 22 2007, 08:46PM
Steve Conner wrote ...
Steve, are you familiar with the term ''WTF factor''?... Because that is exactly what I met after trying to get on with Pspice. And I'm a specially bad case.
As of now, I simply couldn't ever been bothered because I would need like several months of full devotion to get through it.
There are too many things that need to be learned by heart- it is sort of like a programming language.
Having things like scope among parts toolbar as in EWB is in other case really annoyng thing, I wouldn't expect that for any serious software.
We use EWB at school, I sort of learned to use it but I don't like it.
Lots of things that work perfectly well in reality simply don't work there for unknown reasons.
I could never get things like royer oscillator or halfbridge-driven series RLC to work properly.
In any case, effort of making any more complex simulation to work was not worth of simply building the real thing.
If I knew to use spice well it would probably save me lots of time and teach me lots of things.
I just can't get solaced enough to devote myself to it. frown
Sat Dec 22 2007, 08:54PM
All i can say is, ive been using pspice for awhile now and its all pretty automatic for me. When i started it was like trying to budge a mule, but now my simulations almost always work, and i can do whatever i need with it. Its worth the time investment in my opinion. Ive seen some other simulators out there that didnt seem to give as detailed results as pspice is capable of (provided you know how to tell it just how detailed you want it!).
And to be on the topic of CM IGBTs... i even used pspice to simulate the reverse diode recovery problem i was seeing with the CM300s, and with the appropriate inductances in the model, the results were stunningly similar to what my scope probe measured (about 100% overshoot with ~10MHZ ringing). Of course its very easy to do something wrong in simulation and have it look 10X better or 10X worse than reality, so i like to do a little variation of parameters and see the effects of things to get a feeling for how the simulation works.
JohnT
Sun Dec 23 2007, 05:08PM
JohnT Registered Member #224 Joined: Mon Feb 20 2006, 07:53PM
First, thanks for sharing your design, it's nice to see such collaboration. The other thing I wanted to mention is that for some strange reason I cannot open the expressSCH schematic. I'm using expressSCH 6.1.2 (latest) and I get an error that says "... is not a valid expessSCH file". I can open the PCB layout no problem. Any ideas or maybe you could post a .pdf file?
Thanks
Tue Dec 25 2007, 03:20AM
The schematic is a PSPICE file, not an expresspcb file.
