  • Guests: 61
DIY spun toroids
Derek_L
Wed Dec 12 2007, 04:13PM
Derek_L Registered Member #1125 Joined: Fri Nov 16 2007, 09:13PM
FAKE!
He clearly photoshopped the video and the pictures.
Tom540
Wed Dec 12 2007, 05:36PM
Tom540 Banned on 3/17/2009.
Damn those look awesome!! I want some!! I could definitely use both sizes as well. You should mass produce these, it's your calling. I would be willing to buy a few dozen.
Wed Dec 12 2007, 10:44PM
Daniel Uhrenholt Registered Member #125 Joined: Fri Feb 10 2006, 01:52PM
Thanks all.
Marko,
Yes with my ”magic” spinning stick and a lathe:-)
Goldsphere,
It`s made out of 1mm copper plate.
Shan,
The first 3 forms I made are steel mandrels, but it was a pain in the ass to make… So now I use hardwood (oak) for the mandrels.
I use a little cutting oil as lubricant, it’s a little messy but it works great. And it’s easy to remove the oil when I’m done with the spinning part.
I flame solder the two parts together, because I think it looks a lot better…
Derek L,
Are you blind, or …
Here are some pictures and a new video of the 195*50mm toroid.
Video Link2
Pictures of toroid(s) and mandrels:
1197498771 125 FT35801 Parts
1197498771 125 FT35801 Toroids
Maybe I will sell a few toroids next year. But I don’t want to make a whole lot of toroids, if I can’t sell any of them...
Cheers, Daniel
Tom540
Wed Dec 12 2007, 10:56PM
Daniel Uhrenholt wrote ...
Well I would be interested in about 30 or so of the bigger ones.
Herr Zapp
Thu Dec 13 2007, 12:18AM
Daniel -
A few more questions on your beautiful copper toroids -
1. Do you start with fully-annealed 1mm copper sheet, or is it just in the as-rolled condition?
2. Do you need to stop and anneal the shell part-way through the spinning operation?
3. When soldering the two shells together, do you add any kind of alignment features to one of the shells, or use some sort of holding/alignment fixture, or just set one shell on top of the other and use a steady hand?
4. When you say "solder", do you mean conventional tin/lead solder, high-temperature silver solder, tin-based lead-free solder as used for copper water pipes, or something else?
5. Is the tip of your form tool just a polished full-radius?
Shan
Zum Beispiel
Thu Dec 13 2007, 12:40PM
I'd definately be buying some if they don't cost too much... How much would you charge for the larger ones?
Derek_L
Thu Dec 13 2007, 07:47PM
No it was my lame attempt at sarcasim.
They just look so professional and well done.
Its like when your really good at a FPS game and someone says your using an aimbot.
It was ment to be a compliment :)
Thu Dec 13 2007, 08:23PM
Derek L,
Surry about my misunderstanding…
Shan,
I think a little googling would answer most of your questions…
Zb,
The price for one of the bigger toroids is 140$, this price is with shipping in Europe. You have to pre-order the toroids, so I can make an overview of how many I have to make.
And the price for one of the small ones is 30$, and you can get two for 50$ without shipping. I don’t intend to run more than one production of these.
The toroids are spin polished and soldered together.
If people are interested in the toroids, I think this thread should be moved to Sale and Trade.
Email me if you have any questions.
Cheers, Daniel
Zum Beispiel
Thu Dec 13 2007, 08:31PM
Dang, that is a bit out of my price range sad I can't justify spending 140 bucks on a toroid (and I do realize it's not a bad price, at all). Putting that toroid on would probably double the value of the coil. mistrust
Oh well, thanks anyway.
Thu Dec 13 2007, 08:48PM
Zb wrote ...
Really? cheesey I think it would raise the value of my coil a few orders of magnitude..
Nevertheless these toroids do look really professional.
J.M.
