  • Guests: 38
Hanzie (31)
badger (52)
h3X (40)
01/12 RoV IW3IPD (63)
Charging 1.7kj Cap Bank from batteries
FastMHz
Wed Mar 08 2006, 10:11PM Print
I would like to find the easiest way to convert 12v DC into 700v-720v DC so that I can more easily launch my ringrockets from a field without an AC power source. It needs a bit of current, say 0.5a, so the bank charges in a few seconds rather than minutes. When I say "easiest" I mean with fewest components without having to etch a PCB.
Wed Mar 08 2006, 11:30PM
There are many circuit possibilities,
the limitations will probably come from the battery.
e.g. 1700 Joules in 10 seconds = 170W at 100% efficiency
for a 12 V battery that's 14.17 Amps
probably nearer to 20 Amps considering losses.
That's a good NiCd pack or a large/heavy lead-acid battery.
(anyone have a good alternative for high-current batteries ? )
All things considered, it would probably be best to get a commercial 12V invertor to use the same design as indoors.(eBay?)
The weight will be less than the Battery.
An invertor is always 'nice to have'
EDIT
So compromise between
-Energy stored in Capacitor Bank
-Time to charge Capacitor Bank
-number of firings between Battery recharge
Your requirements are very similar to high power Xenon flash requirements, and almost every energy pulse discharge project on this forum!
-Cost/Weight of Battery
Bjørn
Wed Mar 08 2006, 11:45PM
Modern lithium and NiMh based batteries can take those currents and more without any problems. Have a look at sites like http://www.ezonemag.com/ for high power battery packs.
A 230V inverter with a voltage doubler sounds like very good idea. Some of them are easily adjustable within a certain voltage range.
FastMHz
Wed Mar 08 2006, 11:51PM
Thanks for the replies guys! I was beginning to think an inverter was probably easiest too, and they're cheap on ebay which is good. I'll be using a small 12v@5a GelCell to charge, it can handle high current draws for short periods.
The best batteries on the planet are Lithium Polymer....they're also most expensive...but you can see there capabilities in my RC project here. I won't be using batteries like this wink
Dr. Shark
Thu Mar 09 2006, 08:56AM
A few NiMh racing packs are probably the power source of choice, they take abuse well (LiPo does not), and they are cheap.
If you feel like experimenting you could try rigging up a simple blocking oscillator using the transformer from an old PC power supply in reverse and a single transistor (e.g. from the same PC PSU). the circuit is basically this Link2 there was also a thread about that on the old board, but I can't find that now. Efficiency probably wont be that great, but hey, just chip in another battery pack and you probably still save weight compared to using a "proper" inverter
FastMHz
Thu Mar 09 2006, 06:37PM
That has got to be the cheapest, simplest inverter I've ever seen! I can certainly find uses for that - thanks for sharing it! I'm a little doubtful as to its usefulness for charging such a huge cap bank in about 20 seconds due to current draw though.
Dr. Shark
Fri Mar 10 2006, 09:00AM
If you use an ATX PSU transformer, which is good for at least 200W, you will probably get a bit more current than with the ferrite bead smile
This suggestion acutally came from Dan (EVR) or Mike (Mikes Electric Stuff), aparently he managed to get quite a bit of power through. You need a few extra components if you do this, like a Zener to protect the transistors base, some snubbing components etc.
mikeselectricstuff
Sun Mar 12 2006, 09:52PM
A while ago I was looking at simple, quick, crude and brutal ways to get a few hundred volts at high current (for an argon laser pointer project I never got round to finishing). I found that a simple blocking oscillator based on a PC power supply transformer worked pretty well. For 700 volts you might need to stick a doubler on the output.
rupidust
Sun Mar 12 2006, 11:17PM
rupidust Banned
Registered Member #110 Joined: Fri Feb 10 2006, 12:23AM
FastMHz wrote ...
Is 12v absolutely necessary? To charge 1700J in 20 seconds requires an 85 watt charger. I got a 100 watt booster that uses 24v. Uses 24v so that the current consumption is lower. It just a booster converter, real small size and parts count.
FastMHz
Mon Mar 13 2006, 12:26AM
12v isn't mandatory, but preferable since that's what vehicles use. I've already ordered a cheap 140w inverter off ebay and will use that. Thanks for the suggestions!
