  • Guests: 15
kirE (35)
Sparkie (47)
indheat lover (36)
11/22 Goodchild (33)
11/22 pauleddy (33)
11/23 Munkey (31)
4hv.org :: Forums :: Attachments
Next topic »
How to add thumbnailed pictures to a post
Bjørn
Tue Mar 07 2006, 08:45PM Print
Post your pictures here on the Attachments forum, then you insert the corresponding link/img tags in any of your posts you want to add pictures to. If you click the edit Edit button in the post with your pictures you can copy the link/img tags that the forum software generated without you having to type them in. The pictures must be 600 pixels wide or less. If they are wider you have to include the width parameter in the img tag.
Example (replace any ( ) with [ ]):
[size]
(link=http://4hv.org/e107_themes/4hvtheme1/images/logo.jpg)
(img:width=200)http://4hv.org/e107_themes/4hvtheme1/images/logo.jpg(/img)
(/link)
[/size]
It will display a clickable thumbnail like this:
Logo
If you don't want to link to a larger version of the picture you use the img tag alone:
[size]
[/size]
It will display a thumbnail without a link like this:
Logo
Remember, it is important that you double check your post to make sure everything is correct. It is easy to make a mistake and the moderators may delete your pictures or even the whole post if you mess with the formatting of the board.
Jasonr
Mon Apr 17 2006, 06:34PM
Jasonr Registered Member #167 Joined: Mon Feb 13 2006, 06:41PM
Thank you this is very helpful info.
you can also browse to files that are on you web site and add them from the http address.
Part Scavenger
Thu Apr 20 2006, 03:28PM
Thanks Bj'orn! That is great info.
Nucleophobe
Mon Mar 05 2007, 02:05AM
Nucleophobe Registered Member #108 Joined: Thu Feb 09 2006, 11:44PM
oops
Chris Cristini
Fri Oct 17 2008, 01:48AM
sorry i will fix it asap.
GluD
Sun Nov 07 2010, 08:37PM
GluD Registered Member #1221 Joined: Wed Jan 09 2008, 06:17PM
1289162236 1221 FT3458 S6300116
AstroBoy
Thu Mar 24 2011, 06:06PM
AstroBoy Registered Member #3765 Joined: Sat Mar 19 2011, 03:00PM
I see other members have photos in their post that are not here on the attachment page so what gives i.e. how did they do that? lol
How do you upload a photo from your PC into this attachments forum?
How do you upload a photo from your PC into your message?
If nothing else where can I read how its done?
I see the insert image here icon {img]mypicture.jpg[/img} in the message box so do I copy/paste the photo properties from its location in my documents?
Wish it were just select and upload your photo or something simple like that…
Newton Brawn
Tue May 28 2019, 02:42AM
Newton Brawn Registered Member #3343 Joined: Thu Oct 21 2010, 04:06PM
trying add picture
Newton Brawn
Tue May 28 2019, 02:44AM
trying add picture
alo
Wed Jun 21 2023, 03:45PM
E.TexasTesla Registered Member #4362 Joined: Sat Jan 21 2012, 03:44AM
test
