  • Guests: 48
01/23 GimpyJoe (36)
01/24 OnFire (64)
01/25 Evgenij (60)
electrolisys of water
rp181
Mon May 19 2008, 01:04PM
O.o old thread. I found out carbon rods give Co2 and O2 instead of just O2.
cbfull
Wed May 21 2008, 02:56AM
cbfull Registered Member #187 Joined: Thu Feb 16 2006, 02:54PM
To get the most surface area and the least amount of corrosion, I recommend using sodium or potassium hydroxide dissolved in distilled water, and for electrodes I hear that stainless steel pot scrubbers are about as good as it gets. I've seen these pot scrubbers at Walmart before, and if you want to go one step further, McMaster Carr has 316 stainless steel wool pads available in different grades.
badastronaut
Wed May 21 2008, 05:34AM
badastronaut Registered Member #222 Joined: Mon Feb 20 2006, 05:49PM
For ease of access, you can use stainless steel spoons and forks. Eventually they will get a few little pock marks though...
waffle
Wed Jun 18 2008, 02:21AM
waffle Registered Member #642 Joined: Fri Apr 13 2007, 10:19PM
For bigger carbon rods you can look in those huge square lantern batteries.
rp181
Wed Jun 18 2008, 02:44AM
As i said before, carbon gives co2. I ended up using some metal plates i found at home depot in sodium hydroxide, all in 3in PVC. A bubbler was made with 3/4in PVC. I also did the poor mans arrestor (loop of tube with water) and 2 arrestors. I did that after having one blow up and give me chemical burns around my eye =p
Electroholic
Wed Jun 18 2008, 04:37AM
how does it give off co2??? unless you are talking about carbon arc under water.
rp181
Wed Jun 18 2008, 03:32PM
oxygen forms on the carbon rod, and combines with some of it. Someone told me this, i think it is true because that gas burning is way less powerfull then of of metal plates.
Quantum Singularity
Wed Jun 18 2008, 11:27PM
RP - I wonder if this is similar to the electric CO2 generators you can get for aquariums, they use a carbon block and stainless steel holders in the water, so makes sense that O2 combined with carbon can produce CO2. For the record though those CO2 generators for aquariums are a waste of money and much better to set up a pressurized gas tank.
rp181
Wed Jun 18 2008, 11:40PM
meh, i gave up on this untill i find a sutible power supply (not really looking), i still have my setup.
