  • Guests: 67
wireless 'power' transfer?
Tue Mar 07 2006, 02:01PM
I don't think the Fres's really matter that much. Even if the primary and the two secondaries all had exactly the same Fres, as soon as the three coils were coupled together, the system would have three different resonant frequencies- that's what the maths predicts.
Tue Mar 07 2006, 02:25PM
For transfer itself exact resonance is top priority - just compare my coils with blackplasma's - big difference.
Main circuit is just two LC's coupled with small capacitance (between topoads) and ground.
When resonator is resonant it acts as zero impedance to TC and drops its Q directly (also checked) drawing current limited by capacitive impedance, C is very small but frequency high so small current cna pass.
With enough current resonator will (only at its Fres) build up high voltage if losses are not too high.
So can you explain a bit that about 3 different frequencies rolleyes
Or you just tought about breakouts?
Tue Mar 07 2006, 04:08PM
Richie Burnett explains on his site how coupling two resonators causes "frequency splitting"-
If you couple three resonators, the theory is the same, except you get three split frequencies rather than two. My twin DRSSTC had three resonators: one primary tank circuit and two secondaries.
Tue Mar 07 2006, 06:38PM
Frequency splitting occurs because in a coupled system, the more the system is coupled, the more capacitance each side "sees" of the other. In a dual coil system, this creates the classic double-hump response.
Avalanche
Tue Mar 07 2006, 06:58PM
I've sucessfully transferred power from my small 1Mhz coil (without breakout, and a ball bearing topload) to an insulated aluminium plate. A light bulb in series with the plate and ground will light up brightly a few inches away, so the reciever doesn't have to be tuned in this case. It's just capacitive coupling between the coil and the insulated plate. Tesla has a patent for this, and it's where I got the idea - 'method for utilisation of radiant energy'. In his system he is charging a capacitor and discharging it at intervals, but I haven't managed to make it charge a cap yet....
I am currently working on some equipment for measuring the efficiency of the transfer - but I haven't touched it for a long time!
Tue Mar 07 2006, 07:32PM
wrote ...
TCs and probably magnifiers even better can be used to transmit usable amounts of power over distances.
In all fairness to Mr. Nikola Tesla, he was trying to transmit enormous amounts of power wirelessly over thousands of miles, not a few feet in a laboratory. Its a huge stretch of the imagination to be able to say that TCs and magnifiers can transmit "usable" power wirelessly over distances by your experiment alone.
Tue Mar 07 2006, 08:03PM
Well distances for me (obivously) means tens of centimeters (not miles) cheesey
You didnt notice that's the funny part of post smile
And sory about bothering about frequency split, you confused me at first.
Maybe wanted to use ionosphere as conductor, some earth resonances or etc. to drasticaly improve the transfer that could in basis only be capacitive coupling method, but that's off the topic (and maybe even forum).
Plate to ground must be very close to coil in order to receive some amount of power, as bulb shows high impedance compared to grounding around, so i doubt its some huge efficiency (mine is, lol, also about 10 -20% cheesey so dont care)
cheers
Hazmatt_(The Underdog)
Tue Mar 07 2006, 08:22PM
My power input is about 750-800W, I would know for sure, but I haven't hooked up my wattmeter to my system yet.
My 'sympathetic' or external resonator to the system was about 3' away from the topload with its wire pointing in the air. I think at best I had some 4" arcs coming off of it, but I had no ground plane near that wire, so my best guess is I may have had 5" arcs to ground target.
I just wanted to make sure that it was known that my arcs were freestanding and not encouraged or drawn off by a grounded target.
Tue Mar 07 2006, 08:44PM
Nice, hazmatt, if you can drav inches long arcs you can draw out a lot of power resonator, even when its so far that it doesnt throw any sparks at all.
You can maybe try few windings + bulb as I did smile
ALso you can try ground shield on TC (dont know how would it help in SGTC) and of course don't let any streamers from it for maximum e field.
Anyway when scaled down its far better than my experiment, good job.
teravolt
Tue Mar 07 2006, 08:49PM
It has been my experience that placeing a secondary coil next to an active tasla generates its own sparks. Tesla did this at colarado springs.
