  • Guests: 43
[moved] 24,000j Capacitor Bank (Now Complete)
FastMHz
Sun Nov 18 2007, 05:38PM
Charging will be accomplished via two MOTs in inverted phase series...I still need to find two identical MOTs though...
Derek_L
Sun Nov 18 2007, 10:04PM
Derek_L Registered Member #1125 Joined: Fri Nov 16 2007, 09:13PM
I have a feeling this is going to be 4hv's first snuff film :P
FastMHz
Mon Nov 19 2007, 02:41AM
lol......hence my remotely controlled trigger....I don't want to be near it!!!!
Shaun
Mon Nov 19 2007, 06:15AM
I wouldn't want to be near 24kJ going off in a fraction of a second, either...especially if the coil (or some other component) should decide to explode.
Kizmo
Thu Nov 22 2007, 07:48AM
Nice bank you got there!
I think i should do the same, friend of mine (who works at local power station) said that they have few hundred 350VDC/3300uF capacitors taken from large inverter. I could get them for free :D
That is HUGE pile of capacitors.
Thu Nov 22 2007, 07:13PM
... pulls out a calculator ... hmm ... 3300uF @ 350VDC works out to 200 joules each!
You can build a heckuva coilgun with just a small bank of those caps. You could even build a really nice low-power demonstrator with just one capacitor. And then go into production mode selling them as christmas toys. Umm, no wait, there just might be some safety agency who could have just a tiny little problem with that.
Cheers, Barry
Heck is for those who don't believe in gosh.
JoeDarkon
Thu Nov 22 2007, 10:05PM
JoeDarkon Registered Member #485 Joined: Sun Jul 09 2006, 01:14AM
maybe you can build something to compete with the latest navy railgun : ) Link2
FastMHz
Sat Dec 01 2007, 01:50AM
I've totally redesigned fastmhz.com into a blog where I'll be putting the juicy little tidbits relating to this project as it progresses....I'll of course update this thread time to time as well. Cheers! ~FM
Jasonr
Fri Dec 14 2007, 10:35PM
Jasonr Registered Member #167 Joined: Mon Feb 13 2006, 06:41PM
So are the cans grounded???? if you are running a series parallel situation you will have can cases at different potentials.
Also if one can shorts(which is how it will fail) you will have all the other cans helping it fail that is in parallel with. I suggest you make a case of it. of some kind. Distance may not be a reliable substitute, but in combination with a case or a cover would be.
Logan Kennedy
Mon Dec 24 2007, 05:02AM
Logan Kennedy Registered Member #1103 Joined: Mon Nov 05 2007, 06:02PM
Wow, that's beyond amazing!
I can't wait to see the completed project. The switching mechanism will have to be beyond heavy duty to switch this amount of energy. If it's not designed properly to withstand such a large amount of energy it will NOT survive.
I cannot imagine the blast wave from a 24KJ short circuit.
