  • Guests: 38
williamn (48)
ReddyK (57)
Birdman (31)
12/14 M.A.D. (32)
12/15 marko666 (58)
12/16 Will T (16)
diode mounting
Desmogod
Mon Mar 06 2006, 12:40AM Print
Does anyone see any issues with mounting the diodes like this?
I LOVE these AMP connectors, make swapping out blown FET's very easy... mistrust
1141605417 139 FT1630 00004
1141605461 139 FT1630 00006
Mon Mar 06 2006, 12:50AM
Depending on the design and requirements, there is a LOT of inductance there by doing that. Probably wouldn't be the best for high current full-bridges.
Dan
Reaching
Mon Mar 06 2006, 06:36AM
i already used this technique in some of my smaller sstcs and it seems to work without problems. of cource, inductance is a problem making the fets start ringing on power on, . with lower power sstcs that should be no problem but if you want to build a drsstc or a higher power sstc i would stay away from these connectors.
GODSFUSION
Mon Mar 06 2006, 06:43AM
GODSFUSION Registered Member #157 Joined: Sun Feb 12 2006, 08:00PM
The litte eight pin IC holder things for easy swap out. for pretty good for me.
- Wayne -
Mon Mar 06 2006, 11:13AM
It does add inductance like EVR said, but if you crop the device leads as short as you can, it shouldn't be too bad.
Dr. Shark
Mon Mar 06 2006, 11:20AM
Would adding a ferrite bead not accomplish exactly the opposite of keeping the leads short? As I understand, adding a high permeability material will increase the inductance by 100 or so, which is the last thing you want, isn't it?
Mon Mar 06 2006, 11:58AM
Yes, I don't see how a ferrite bead will help either.
Desmogod
Tue Mar 07 2006, 12:31AM
It's not going to be used for major current, so I think it should be ok.
The only other option is to bend the legs of the IGBT's to a right angle, then mount the diodes behind them on the pcb.
Makes heatsinking them a pain in the neck.
And no, I'm not man enough to build an SSTC that needs no heatsink on the diodes. Yet.
Dr. Shark
Tue Mar 07 2006, 08:53AM
sorry for OT, but what kind of driver are you using? I would suggest a PLL, it seems to become very fashionable and thats for a reason!
Tue Mar 07 2006, 07:28PM
Alternative to screw terminals would be those flip top lead clampers used on most hi-fi units.
If anyone wants some then let me know as I have lots :)
-A
"Bother" said Pooh, as he discovered the coke had been cut with fibreglass powder...
