  • Guests: 41
David (39)
12/25 Kolas (18)
12/26 buxtronix (50)
Spark Gap Materials
GODSFUSION
Tue Mar 07 2006, 09:45AM
GODSFUSION Registered Member #157 Joined: Sun Feb 12 2006, 08:00PM
joe doh wrote ...
Titanium is about the worst possible choice, what makes you think its good for a spark gap?
It was a spur of the moment thought cu i got several rings. I was thinking Voltage multiplyer and not so much TC.
- Wayne -
Tue Mar 07 2006, 10:16AM
As far as I know, spark gap technology and theory hasn't evolved much since the early days of wireless, so most ofl the information that you Google is relevant.
From the little experience I have, iron/steel SG electrodes are cheap and easy to get
(dome nuts etc.) but being ferromagnetic they're not ideal.
The WORST shape for a spark-gap is thin/pointy because 'pointy' electrodes
-need the largest gap for a given breakdown voltage
giving a relatively high ON resistance (energy losses)
-cannot remove heat from the arc quickly and so overheat/melt/burn/vapourise
the vapourised metal ions 'hanging around' in the gap reduce the firing voltage
Tungsten, being the highest melting-point conductor that we can easily obtain
(with a reasonable work function)
is one of the best choices of spark gap material.
Forced air will also help cool the electrodes AND blow ions away from the gap.
For a TC, no matter how crappy the SG, forced air makes a HUGE difference.
For a low prf Marx etc you could just use thumbtacks etc..
Dr. Shark
Tue Mar 07 2006, 10:44AM
Acorn nuts seem to be the spark gaps of choice for Marx generators. They are sphrical, and since you can attach them to a screw it is easy to fine tune the gap distance.
Jrz126
Tue Mar 07 2006, 10:06PM
Jrz126 Registered Member #242 Joined: Thu Feb 23 2006, 11:37PM
Is there a rule of thumb to use for determining the diameter of the electrodes?
Anybody else have experience with getting tungsten from welding supply shops? I think I'm gonna look into that.
Self Defenestrate
Tue Mar 07 2006, 11:34PM
It shouldn't matter too much, but I'd go for something like 3/8"D, something with some mass to cool itself.
