  • Guests: 28
12/29 Cprossu (40)
12/29 Kokamo (46)
12/29 GalliumMan (60)
CCPS (Capacitor Charging Power Supply)
Sun May 11 2008, 03:09PM
All,
We had a bit of progress this wekend, working on the rectifier and the transformer/rectifier oil tank.
The rectifier:
1210517435 205 FT30311 Rect1
Is 4 strings of 16pcs MUR8100C Which are ultra fast recovery 12A 1000V diodes. And the cheapest diodes we could find in this range.
With a 2.5V forward drop, and an estimated 2A avg. we are looking at up to 80W loss per string, or 320W total rectifier loss.
That`s why we fitted generous heat sinks:
1210517887 205 FT30311 Rect2
We are already considering to fill the tank with cooking oil, to cater for our needs for fried chips.
To keep things under thermal controll, and also for insulation purposes, we are building an alluminium tank, with heat finns,
1210518158 205 FT30311 Tank
Not welded yet, it will also hold the high voltage transformer.
1210518223 205 FT30311 Tankup
The future progress will be featured in our next installment.
Cheers, Finn Hammer and Daniel Uhrenholt
Sun May 11 2008, 03:37PM
Cheers guys, that tank is looking amazingly bastard! smile Make sure to put some cool looking bushings and a conservator tank atop of it wink
Were you thinking about putting the tank capacitor and inductor under oil too? How hot do they get?
Regarding rectifier dissipation:
Have you actually tried putting 2 amps through those diodes and measuring the forward voltage drop?
The 2.5 volt figure you stated seems to be specified for full 12A, and temp of 25 deg. C, at just 2 amps I'd expect it to be much lower, maybe 2x or 3x lower. Temperature rise will reduce the voltage drop too.
Some people are afraid of possible voltage disbalance caused by unequal junction capacitances, and use resistors in parallel with each seriesed diode. I'm not sure how big problem that actually is... but I'd hate to blow such a beautifully (and painfully) constructed diode string.
Sun May 11 2008, 03:38PM
Finn, that looks awesome! 0_o
Sun May 11 2008, 04:44PM
Marko wrote ...
No, the cap is staying in the cabinet for now. We have not seen any heating yet, but have not gone to high amperage yet either. Perhaps a CELEM cap will be needed, we`l have to see about that.
Marko wrote ...
You are right. I didn`t manage to find the 2.5V figure this time.
Curves suggest around 1.3 to 1.5 volts drop, which pleases us immensely.
Marko wrote ...
We have been considering this, and there is room for surface mount resistors, so we will perhaps do that.
Cheers, Finn
Mon May 12 2008, 09:21AM
If the diodes are avalanche rated, there may be no need for balancing resistors. I'd be more worried about the small clearance between all those sharp-cornered heatsinks, even under oil.
GeordieBoy
Mon May 12 2008, 10:30AM
If all diodes are from the same manufacturer, (and ideally from the same LOT code) there should not be a problem. The SLR inverter provides a sinusoidal current to the rectifier bridge so it is less harsh on the secondary-side rectifiers than a hard-switched inverter.
One observation: If you turned the rectifier board through 90 degrees it would allow the cooling liquid to flow more easily between the heatsinks as it rises through convection. Heatsinks in a horizontal orientation across the flow of air (or cooling fluid) don't perform quite as well. Just an observation - surely not a problem.
Oh, and that is one awesome looking cooling tank! smile
-Richie,
Sun Jun 08 2008, 01:07PM
All,
Daniel welded the tank, and brought a nice thick slab of white POM for the lid.
After the 28 holes in the perimeter were drilled, and the corners rounded, the case now looks like this:
1212923660 205 FT30311 Kasseudv
The rectifier and the transformer were positioned on the lid, which looks like this:
1212923728 205 FT30311 Indmad
After a lot of headscratching, and catalog browsing, we decided to use a 37 pin circular connector between the primary coil and the switching IGBT`s.
Each pin is good for 13 ARMS so with 15 pins in use each way, there is a little headroom. I have used an identical connector for a disk shooter pulsing in the region of 20kA, and it still can come apart, so this ought to work.
To provide the holes for the connectors, the nice little Wohlhaupter boring head has just done it`s thing again.....
1212930336 205 FT30311 Wohlhaupter
We are waiting for the parts now.....
Cheers, Finn Hammer & Daniel Uhrenholt
Dago
Sun Jun 08 2008, 01:24PM
Looks AWESOME!
Sun Jun 08 2008, 03:49PM
Yikes Finn, why so many holes around the rim?
The upside-down design of everything with connectors on the ''floor'' is really clever.
The transformer looks really sexy in that second pic, but I keep wondering if it's secondary winding is a bit overkill?
I thought you were going to use some smaller ceramic bushings for the low voltage in, but the connector is a rather neat solution too.
What kind of bushing are you going to use for HV? And are you going to have some sort of expansion tank for the oil?
Sun Jun 08 2008, 06:22PM
Dr. Arc flash wrote ...
That`s to increase the chances of keeping the oil on the inside of the tank, by providing an even pressue on the seal. Of course, oil is likely to wick up trough the multipole connector..... frown
Actually, the "floor" is the lid, so the transformer and rectifier is suspended from the lid rather than standing on the floor.
Overkill? maby. I hope so, because that`s the name of the game smile
We are going to use standard N Clamp Plugs for RG213. The RG213 will probably be stripped of it`s outher shell, as well as the braid.
Cheers, Finn Hammer
