  • Guests: 27
10/09 sbs_2010 (34)
10/09 SoundDoc (50)
10/10 Ryan Parle (44)
1st timer with Tesla Coils (coil kicks ass)
Kizmo
Tue Jul 31 2007, 04:17PM Print
Hi!
Im 1st timer with RSG tesla coils and im planning to build my own. I did some drawings Link2 and now i need word from experts if there is design flaws or something that need to be changed before i build anything. There will be powerful fan for RSG and RSG electrodes will be TIG welder wolfram electrodes.
UPDATE 30.4.2012
This coil is kicking ass!
Spec:
200x740mm secondary, about 1300 turns
10 turn primary
74.5nF 45kV "MMC" made out of 6 General atomics pulse capacitors
ARSG
Huge 3-ring topload
DC Resonant charging topology, 14.2kV charge voltage
Rectified 3 phase pole transformer as power source
1335776213 599 FT29255 Framecap1
Secondary, one topload ring and base are still same original stuff i had when this coil first fired almost 5 year ago. It has been very interesting experience so far. Last night i burned out 3ph rectifier (24kV 700mA). I think common mode overvoltage caused this. More protection is needed and new 50kV 6A rectifier is under work ;)
Wonder if i can push it even harder.. :p
Tue Jul 31 2007, 08:43PM
If you could convert the MOT output to dc and use resonant charging I think you'd get better results.
Kizmo
Tue Jul 31 2007, 08:47PM
That is one of my future plans but i think its better to start with AC coil. I got idea about coil like this from tesladownunders web page Link2 Pretty amazing how long sparks is possible to get from coil like that.
Hazmatt_(The Underdog)
Wed Aug 01 2007, 12:28AM
You're going to need to take some special precautions for the current involved with your setup, its a lot of current!
Look at the destruction from my 60mA setup:
These were the old electrodes, broken circuit board drills. They have a Tungsten core, but still disintegrated
012f
It's hard to see, but the arc causes basically a weld pool to form on the set screw, destroying it after a while. You might want to use a heavy brass stud or something for this part.
011f
Going through the rebuild process and adding 1/8" 98% Tungsten stationary electrodes.
Your safety gap is going to have a lot of problems with power arcing if the motor isn't synchronized properly, and that's a huge problem with these little sewing machine motors. They don't stay at one speed no matter if you use a solid state control or variac. To regulate one of these motors you would need a closed loop control with PID.
This one 'gets the job done' but not the best way. If you have the opportunity, go for a motor that is a fixed speed or 90VDC motor with controller.
006f
007f
Kizmo
Wed Aug 01 2007, 08:11AM
What would be the cheapest way to get around this problem? Maybe i just don't put any safety gaps for MOTstack because MOTs are almost indestructible and if one dies in time, i can get new from junkyard for free (actually i already got about 20 MOTs here). How about jakob's ladder style safety cap, it will at least shut the arc off?
sparky
Wed Aug 01 2007, 05:25PM
I have been using thickest Zirconium Tugsten electrodes avaliable on the welding market. They survived everything I threw at them --- I've run quad pack MOt supplies at 400mA 10kV. Yet again I do run these electrodes at 10,000 rpm using an el'cheapo angle grinder.
Thu Aug 02 2007, 12:55AM
What you could do is run your system at 3600 RPM. I designed mine for 1800 RPM, but because I'm trying to limit the stress on the NST, the gaps still fire over. When I speed up to 3600 the safety gap stops firing because I'm no longer firing at the peak of each half cycle, I'm firing twice each half cycle and the output is roughly the same. So if you set the gaps to fire at the peak you're going to have to trigger your discharge sooner to eliminate the safety gap breakdown.
You could set the gap wider but I would be cautious when doing it since you're already stressing the mots insulation.
Thu Aug 02 2007, 11:13AM
The cheapest way to get around the problem is probably to just increase the speed of the thing, like Hazmatt suggested. If it's going fast enough that the electrodes always present several times per half cycle, and the power supply has plenty of current to charge the tank capacitor quickly, it doesn't really matter whether it's synchronous or asynchronous, the coil will work pretty well regardless.
Kizmo
Mon Aug 06 2007, 02:41PM
I have one question left: I know that with PVC pipes they use carbon based substance to get black color. And that makes the pipe conductive -> useless. But how about black Polypropylene (PP) pipes? I just found source for great looking 160mm (6") Polypropylene pipe but it is black. I tried to measure pipes resistance with multimeter @ 40Mohm range and even when i pushed probes against the pipe wall so that they were only 1mm from each other, i didn't get any sort of reading.
Is this pipe safe to use?
Mon Aug 06 2007, 03:54PM
I don't know about PP, but I've made many Tesla coil parts out of black polyethylene, like primary supports and what not. I've never had any trouble.
