  • Guests: 48
RickR (18)
TheBoozer (58)
invader (50)
TheAncients (32)
01/10 Hanzie (31)
01/10 badger (52)
01/10 h3X (40)
soldering tiny surfmount pins
Wed Mar 01 2006, 12:28AM
I don't know if anyone mentioned it, but I use a hot air station to melt the solder paste for surface mounts. If the pins are that small it will be difficult to hit it right with a solder iron. The air station works perfectly each time.
kell
Wed Mar 01 2006, 03:23PM
kell Registered Member #142 Joined: Sat Feb 11 2006, 01:19PM
What do you mean by solder paste, do you mean flux or do you mean the water-base "liquid solder" for surface mount that you have to keep in the refrigerator? Also, how did you get your hands on a hot air station?
Thu Mar 02 2006, 01:25AM
The solder paste must be kept refrigerated. It is a liquid mixture containing the solder and solidifies when heated.
I got my Hot Air station from Circuit Specialists. It wasn't that expensive. It also works great for shrink tubing!
kell
Fri Mar 03 2006, 01:31AM
I guess you got the CSI825.
Could a person do everything with the basic package or would
he end up having to buy extra nozzles?
I think I may go on ebay and look for used units.
Desmogod
Fri Mar 03 2006, 01:40AM
How about soldering the pins, then using a heat gun to re-melt the solder, and mount it where you need it.
Fri Mar 03 2006, 02:23AM
Heat guns can really heat components to very high temperatures. I would be wary of doing this unless you can be absolutely sure that you don't overheat the component.
Fri Mar 03 2006, 05:55AM
I didn't get anything fancy or any other extra nossles. My station came with three different nozzle sizes. It has worked great each time and I have soldered very small components - about 0.5-1mm components.
kell
Fri Mar 03 2006, 06:17PM
Here's something I just got an e-mail from mpja.
They have a special on a hot air station:
What say fellas, is it a good deal?
Sat Mar 04 2006, 04:17AM
There are a few at the link below. This one is $139 and would do just fine.
It is up to you how expensive you want to go. Mine is bare minimum: air flow and heat control only.
Avalanche
Sat Mar 04 2006, 09:51AM
I've used a hot air gun with great sucess for desoldering smt components - but not tried it for soldering. As long as you heat the component slowly, it should be ok - because the board is originally made in an oven anyway. I've salvaged expensive microcontrollers from work using this technique, and it's why I prefer smt!
