  • Guests: 48
12/06 Dago (37)
12/06 Z28Fistergod (39)
12/06 JonIverson (45)
Marko's DRSSTC v1.1
Tue Jan 23 2007, 03:57PM
Hi... updated with lots of new pics. Added plexi bender and cutter.
Avalanche
Thu Jan 25 2007, 10:10PM
It's coming on really nicely, good work! smile
I remember using one of those hot wire plexi benders at school, problem is the heating wire was way too far down - about 4" from the plexi, and I was never able to get good results. I might have to build one like yours and try it again!
Thu Jan 25 2007, 10:28PM
Hi avalanche
Wire is 3-4mm away from plexi on mine, andI actually toughtto bring t closer, but wasn't bothered to find longer screws (these were already becoming unstable).
Wire shouldn't be too hot but should almoust touch acrilyc for best results.
26.1.07: cut primary supports, and added a pic. They aren't looking too good...
Sat Feb 03 2007, 01:02AM
Hi again.. Updated with some new pics.
One thing that bothers me... C. hooper pointed out steel screws I used on my primary supports.
They are chrome-nickel stainless steel and they don't seem to be noticeably magnetic.
Should I worry about these setting my coil on fire? (plexi wouldn't like to get hot at all.)
I used to have lots of ferrous things around my primary, sometimes even big plates or connection clips and didn't have any trouble...
Dr. Drone
Sat Feb 03 2007, 01:41AM
shades
Sat Feb 03 2007, 02:42AM
Hmm, looks like that offset in your primary is creating a pretty decent hot spot in the flux... I wonder how that affects performance?
But in general, I wouldn't worry about the bolts.
Dr. Drone
Sat Feb 03 2007, 03:56AM
shades
Sat Feb 03 2007, 07:46PM
Thanks chris.. I'l consider this thing lossy if I ever need to run it at 500W or so, I guess I won't have any problems.
Sun Feb 11 2007, 12:47AM
'evening.. Pics of almost finished coil finally! Just have to get some more wiring soldered and hooked up, and I hope for a first light tomorrow.
I also remembered I have an large amount of ceramic caps, in one of old MMC's, laying unused. They aren't best choice, but still much better than few polyester caps smile .
Each capacitor is rated 10nF 3kV, and I have 25 strings of 2 in series for 6kV 125nF, surge impedance ~10ohms. I didn't have enough bleeders for them all, so I just used two seris resistors over entire bank.. hope they won't care! confused
Since there's so many of them, each cap would suffer only 20 amps of peak current if I ran the coil at full 500amps.. with some luck I may get some bigger sparks with them!
Only thing I'm afraid for them is that they'l start to heat up due to losses, and detune the coil all the time due to their gross C/t dependence. Current and frequency are low so I may have some chance.
PS. 26.2. hope to continue this as soon as possible..
Bennem
Sun Feb 11 2007, 08:55AM
Nice looking coil
and well constructed!!
look forward to seeing pics of its first light!
