  • Guests: 42
  • Most ever online: 441
Michael W. (36)
10/05 GhostlyFigures (36)
10/06 Ivan Kalafatic (17)
10/07 Pyromaniac (34)
Breakout Point - Optimum Position?
thedatastream
Mon Dec 04 2006, 04:19PM Print
Is there an optimum position for a breakout point? I've noticed some variation in where I locate my breakout in that further away from the toroid appears marginally better.
Any other tips for breakout location / design? I've just been using a 3" screw laid on top of the toroid.
Thanks
James
Mon Dec 04 2006, 04:50PM
You can try to find the best position with something like that:
http://www.geocities.com/romtcb/obitnail.html
The 1/3 upper part of the toroid seems to be the best.
With short nails the sparks will start at higher voltages but they are longer from my experience...but it will stress a bit the secondary.
Terry Fritz
Tue Dec 05 2006, 06:31AM
Hi,
All that I can add...
For the DRSSTC case where strikes to the primary are "bad"... Adding an arc point off the very top to space is an advantage in eliminating primary strikes. Terminals like to arc off the surface at some odd angle depending on many things... But it is not really important at all..
Cheers,
Terry
