  • Guests: 66
01/13 si2030 (62)
10 Ways how NOT to play with Thermite . . .
robert
Sat Nov 25 2006, 09:13PM
robert Registered Member #188 Joined: Thu Feb 16 2006, 05:18PM
I badly think they put in just a little bit of copper oxide, which is known to violently explode with aluninium or magnesium powder...
Sat Nov 25 2006, 10:57PM
Surely pouring several pounds of molten metal on a big block of ice, it would just be a huge steam explosion?
Sat Nov 25 2006, 11:15PM
Obivously not just steam, but also hydrogen wich gets trapped inside the block and it blows the block up.
From here Link2
wikipedia wrote ...
If thermite is ignited underwater, the molten iron produced will extract oxygen from water and generate hydrogen gas in a single-replacement reaction. This gas may, in turn, burn by combining with oxygen in the air.
Bored Chemist
Sun Nov 26 2006, 10:34AM
That quote from wikipedia makes sense provided that there is air underwater.
Since water expands roughly 1500 fold when it boils I think a steam explosion is perfectly reasonable. I have seem (years ago) video of a pot of molten copper being poured into water. The explosion is pretty substantial and has nothing to do with hydrogen.
Sun Nov 26 2006, 10:42AM
Yep; but this is ice, wich has lot of air bubbles trapped inside wich can ignite with produced hydrogen. When this happens in a closed space it gets quite mad.
Steam could also have played a role here, but I don't know would just it detonate so violently. rather than just 'popping' thermite from the top.
Interesting effect anyways.. wink
ragnar
Sun Nov 26 2006, 10:48AM
Is pyrolysis of the water occurring at these temps?
Sun Nov 26 2006, 03:38PM
Someone needs to try it with a block of dry ice to see if hydrogen is a factor. suprised wink Personally I don't think molten metal is hot enough to dissociate water much, and even if it was, it just burns back into water and doesn't release any more energy than you had to start with.
So I think with dry ice the bang would be bigger.
PS, this thread on the sciencemadness forum Link2 seems to suggest that it's purely a steam explosion, and works with liquid water too. The last post in the thread brings up an interesting point, if droplets of molten metal are mixed with water, the rate of heat transfer could run away as the mixture boils and shakes itself around.
Reaching
Sun Nov 26 2006, 04:18PM
yeah steve is right. they explain it in the video.
the thermite is more than 3000degrees hot. when the thermite comes into contact with the ice block the ice gets so hot that it changes into steam within a few microseconds causing this huge explosion
Sun Nov 26 2006, 04:35PM
Yeah, but to do it properly someone would need a clear area without anything flammable, some huge blocks of dry ice and large amounts of thermite. I don't know how would experiment scale down well!
Lots of steam is definitely produced very rapidly, along with hydrogen.. 50:50 for now? suprised
I somehow felt that steam explosion would need better ''sealing'' for pressure buildup, but I might not be right...
Bored Chemist
Sun Nov 26 2006, 07:50PM
"Yep; but this is ice, wich has lot of air bubbles trapped inside wich can ignite with produced hydrogen. When this happens in a closed space it gets quite mad.
Steam could also have played a role here, but I don't know would just it detonate so violently. rather than just 'popping' thermite from the top."
It's still mainly ice. I'm not sure that a H2 +air explosion would propagate through a mesh of ice and water- after all a copper mesh will stop an acetylene flashback.
You seem not to wish to believe that molten copper certainly detonates when dropped into water; why not?
